I've been happily using TMPGEnc to convert files for a couple of years now, but I'm now having major problems when attempting to convert WMV files to VCD-compatible MPG. All other file types convert fine, and I'm only having problems with WMV.
I can often successfully convert WMV files that are only a couple of minutes long, but longer files are causing TMPGEnc to lock up. They seem to be converting fine at first, but a few minutes into conversion TMPGEnc will suddenly slow down its conversion rate to around one frame per minute, and the "Remaining time" constantly climbs from a few minutes to several hours and then onto eternity.
Does anyone know a solution to this? If not, perhaps there is a better video conversion tool you can recommend.
TIA
The easiest thing to do is to convert the wmv files to avi with huffyuv (Very Fast Codec) using River Past Video Cleaner or any other software you prefer.Then load into TMPGEnc.
Need help merging 720p intro + 840*524 Fraps footage
By Reggaesmurf in forum Video ConversionReplies: 0Last Post: 16th Mar 2011, 04:12 -
Problems with conversion from wmv to MP4
By Dr_Zocki in forum MacReplies: 2Last Post: 9th Feb 2010, 05:27 -
TMPGEnc & EO Video mpeg-2 conversion problems
By jtalpur in forum Video ConversionReplies: 2Last Post: 28th Aug 2007, 16:46 -
TMPGEnc problems with RMVB -> Mpeg2 conversion
By rebel316 in forum Video ConversionReplies: 2Last Post: 7th Aug 2007, 05:33 -
WMV Conversion to Xvid - Audio Synch Problems Again
By TonyRomo1227 in forum Video ConversionReplies: 10Last Post: 6th Aug 2007, 17:32
