    Nov 2004
    East Sussex - England
    Hi
    I live in the UK (PAL/I). I need to buy a new VCR with AV OUT. At present I cannot find one.
    The VCR I want is a Panasonic NV-SV121EB which has TBC.
    But I cannot find out if the AV on this machine is OUT or IN.
    My question;
    Reading up on SCART, it seems that Scart has replaced the AV IN/OUT.
    Is this correct?
    If I use Scart through a switchable phono adapter - will the quality be as good as if I'd used the AV OUT (like my old JVC machine)?
    One other question - the Panasonic VCR states TBC - will this TBC be transferred OUT - in other words is the TBC only for tape playback - or will this corrected signal be output so that I can plug it to my ADVC 100?
    Thank you in advance - Stephen
    Aug 2004
    Florida
    hi,
    Check this website and it will describe scart..
    Jolphil
    http://www.electronics2000.co.uk/data/pinout/scart.htm
    Jan 2004
    UK
    Originally Posted by Dear Prudence
    Hi
    I've just got one of these decks - it has scart, s-video and av out. I'm using av.
    I'm using both a DAC100 (similar to your ADVC) and an AIW 8500 to capture, and the results of both the tbc and dnr functions are captured just fine.
    Seems to be a great unit - very glad I bought it.
