Im trying to conver .MKV to .AVI like Divx/Xvid Vdub Mod doesnt handle .MKV very well anymore....
And MKV Exstract doesnt handle it well the audio is longer than the video once exstracted...![]()
Can someone help me convert this .mkv to .avi im not above buying software if i have to.... Thanks
Have you checked out the GUIDE section to the left of this page yet ?
I would recommend taking a look there first.
Take a look at the 'HOW TO CONVERT' section and you will see a box which says 'Format Conversion' here you can select your conversion type, then click on 'Search or List Guides' and you will be given all the guides for that format.
if virtualdubmod, mkvextractgui and mencoder doesn't work you can't do much...
maybe avimuxgui and http://www.riverpast.com/en/support/tutorials/convert/mkv/avi.php
MKV to Divx / xvid
By onlygk in forum Newbie / General discussionsReplies: 7Last Post: 23rd Dec 2010, 04:51 -
Converting MKV (H264/DTS) + Speedup to 25fps for PS3 Playback > Help Needed
By flexx in forum Video ConversionReplies: 3Last Post: 17th Nov 2010, 06:28 -
Help needed for converting MKV to MKV From FormatProfile5.1 to 4.1
By y0ush4 in forum Video ConversionReplies: 13Last Post: 15th Sep 2010, 04:43 -
Urgent help needed pls. converting mp4 to xvid- cant get sound
By prendersparty in forum ffmpegX general discussionReplies: 4Last Post: 14th Sep 2010, 13:35 -
Mkv to xvid/divx xbox360??
By Ducco in forum Video ConversionReplies: 1Last Post: 4th Dec 2007, 18:17
