I wanted to burn on cd an image made up of three files : ccd, img and sub. I started off with Clonecd 5.0.22 and when I pointed to the ccd file as image file, the "Next" button was grayed out.
I changed "img" file type to "iso" and had no problem at all with Nero 6.6.0.13. Did I do something wrong with Clonecd?
the ccd file could have been corrupt. Depends where you got the files. You can try alcohol 120% as well. It can burn ccd files fine. nero can't handle copy protections schemes the way other programs can. Even if it burned the image it may not work correctly depending on whether the original is copy protected.
Alcohol also burned the cd without a hitch. Access from the software on the cd is all right. Thanks for introducing me to this utility.
Sony ccd-tr360e to pc
By AntiBaltak in forum Capturing and VCRReplies: 3Last Post: 30th Nov 2009, 10:22 -
PV GS120 Defective CCD?
By greymalkin in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 4Last Post: 13th Aug 2009, 09:47 -
Sony camcorder CCD-TR705 vs CCD-TRV95
By younso in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 3Last Post: 8th Jul 2009, 15:32 -
Question how to burn (img, ccd, sub) with Nero
By jimdagys in forum Newbie / General discussionsReplies: 5Last Post: 11th Nov 2008, 08:35 -
Help! having trouble installing anydvd, clonecd and clonddvd
By Ade007 in forum Newbie / General discussionsReplies: 1Last Post: 15th Jul 2007, 17:41
