Is there a way to password protect either an mpeg file or a clip mastered through a dvd authoring program?
I once thought I was wrong
But I was mistaken -
https://www.videohelp.com/faq#copyprotect
https://www.videohelp.com/faq#copyprotectdvd
There is probably an app that can password-protect files, but I would imagine that your end-users would probably require the same program.
There are some tutes for using DVD-lab / DVD-lab pro to create a keypad effect that works on settop players here, here or here that are probably the best I've seen so far. Easy to workaround with the right tools though.If in doubt, Google it.
Protecting a dvd from being copied
By arnold.iceman in forum Authoring (DVD)Replies: 4Last Post: 14th Aug 2010, 10:12 -
Copy Protecting an Image CD/DVD
By Squid_uk in forum Newbie / General discussionsReplies: 36Last Post: 19th Mar 2010, 15:15 -
Protecting My Own Videos From Copying
By moviebuff2 in forum Newbie / General discussionsReplies: 57Last Post: 6th Dec 2007, 16:48 -
DVD-Protecting
By josh22_22 in forum Authoring (DVD)Replies: 9Last Post: 7th Aug 2007, 23:50 -
Protecting DVD
By adamstillwell in forum Newbie / General discussionsReplies: 9Last Post: 30th Jul 2007, 02:48
