Results 1 to 9 of 9
    Jun 2005
    can anyone tell me how to rip a part from a xvid ... ? there is like one min i want from a movie ? how to ? ... and dont tell me virtualdub cant get it to work
  2. well, other than virtualdub, you could load it into Nero Vision Express, goto make movie, add the xvid, edit it to just the part you want and export it. Probably not as clean or easy as a Vdub job, but another solution never the less.
  3. VH Veteran jimmalenko's Avatar
    Aug 2003
    Down under
    If in doubt, Google it.
  4. Member waheed's Avatar
    Jul 2003
    Manchester, UK
    If you cant get virtualdub to work as you suggest, maybe you can explain what problems you are having with virtualdub so others can help.
    Nov 2002
    VirtualDub
    Jun 2005
    "Couldn't Locate decompressor for format "Xvid" (Divx +4 ". and others" )
    Virutaldub requires a video for windows (VFW) compatible codec to decompress video. Directshow Codes, such as those used by windows media player, are not suitable ..
    1. i got Directshow codes installed
    2. and media player is working ...
  7. VH Veteran jimmalenko's Avatar
    Aug 2003
    Down under
    You need a XviD Codec
    Jun 2005
    sweet ....thanx alot ...it worked :P
  9. VH Veteran jimmalenko's Avatar
    Aug 2003
    Down under
    Heyyyyy ...... whaddaya know ...
    This is videohelp.com, after all ...
