Hi-
First open your video in AutoGK. Then hit CTRL/F8. That will cause a new line to appear at the top.
Then you can choose either IDX/SUB files,
or you can choose SRT, SUB, TXT, or SSA format text based subs to use.
Results 31 to 36 of 36
This thread was very helpful to me. For anybody having trouble with audio and the Toshiba SD-185E-K-TB player (video playing okay but no sound), here's what worked for me.
- Open the .avi file with VirtualDub; if you get a warning about variable bitrate (VBR), the audio needs conversion.
- Do File > File information; under Audio stream, check if Sampling rate is 44100Hz, Channels is 2 (Stereo), Compression is Fraunhofer IIS MPEG Layer-3 Codec, and Data rate is 128 kbps; if any of these is different, probably the audio needs conversion (I say "probably" because this is the one type of stream that so far worked with my player, but there may be others).
- To convert the audio, continue.
- Ensure that the Fraunhofer MP3 Codec is properly installed, for example following the instructions here.
- If you had to install the codec, restart VirtualDub and reopen the .avi file.
- Do Video > Direct stream copy.
- Do Audio > Full processing mode.
- Do Audio > Compression, select MPEG Layer-3 and 128 kBit/s, 44.100 Hz, Stereo; if this combination is not available, you need to first do Audio > Conversion and select the desired Sampling rate and no of Channels.
- Do File > Save as AVI and save the converted file under a different name.
I'm missing how to add the subtitle to the project as well. Srt titles, doesn't seem to recognize them in the options.Originally Posted by Gi-Ma-Mi
You didn't see the pics I posted nearly 3 years ago about how to do this? Open the AVI. Hit CTRL-F8. To the right of the new and empty line at the top select your SRT file for inclusion in the AVI.
Hi all, I've followed the guide on how to remove the qpel codec, but i no sound on the converted source. I've tried doing the virtualdub to convert the audio to wav, but in file info i see that my original avi has no compressor, it says unknown (tag2000) and so vdub cannot continue. can anyone pls help?
I have theFraunhofer IIS MPEG Layer-3 Codec installed but vdub still gives me the error "no audio decompressor could be found.." -
Use a utility like GSpot or Mediainfo to see what codecs your video uses. They're also helpful for determining whether or not your videos have QPEL, GMC warppoints, etc.
...but why are you trying to have VirtualDub convert the audio to WAVE format? If you're just trying to recompress an .AVI so that it plays on a DivX/Xvid-capable DVD player, install AutoGK with the ESS option enabled (if you haven't already, and as Baldrick's initial post suggested), and give it the AVI you want converted. It'll do all the work for you.If cameras add ten pounds, why would people want to eat them?
Philips DV624/37 AVI (XviD) Problems (Not QPEL/GMC)-could it be the codec?
By wingalls in forum Newbie / General discussionsReplies: 4Last Post: 2nd Nov 2008, 01:13 -
Easiest way to re-encode GMC avi?
By fayewolf in forum Newbie / General discussionsReplies: 7Last Post: 24th Sep 2007, 14:49 -
Converting DV AVI to xVid AVI (with AutoGK)
By foochuck in forum Newbie / General discussionsReplies: 6Last Post: 5th Jul 2007, 01:56 -
Problem Converting AVI to xvid AVI (using AutoGK)
By foochuck in forum Newbie / General discussionsReplies: 2Last Post: 3rd Jul 2007, 10:57 -
XviD: Qpel, GMC, Max consecutive B-VOPs, and N-VOP ??
By GangstaRap in forum Video ConversionReplies: 17Last Post: 20th May 2007, 04:59
