I just got this burner and i flashed it to LD3540_1W5 for bitsetting.
now, im using TDK dvd-r, made in japans. TY02.
I dont understand why my burn is burning at a MAX of 2.8x.
I tried burning by setting to max.. 2.8x was max. I set it to 8x, 2.8x was max. I dont know what to do to fix it. This media is reliable and i should not be getting these bad speeds. I know i didnt change DMA settings, i dont even know what they do. please help , thx.
Results 1 to 15 of 15
Do you find that the 3540 burns -Rs ok (not making many coasters?) I'm getting ready to buy a writer, and I'm trying to figure on which one to get since i will burn MOSTLY -R &-RW?
I know the 3520a burns -R fine but it does a better job on +R when using bitsetting. My Pioneer 109 though problematic give better quality -R burns when it decides to burn correctly at all.
Update. The 3520a does not burns my TYG03 -Rs fine. I've burned several of them now at varous speeds and the leadin seems to hang and then the burn goes fine. However on playback the discs all skip for a few seconds right at the begining. I'm not sure if the 3540 would have the same issue but it's worth checking into. IMO NEC has always been better with +R media.
I do not believe its my powersupply. I dont have too much running on my antec truepower
Thanks , thats some of the answers i'm looking for. As said, I want a burner that burns good at -Rs &-RWs. So is it now Benq 1620 ? or some one mentioned a plextor being good with -Rs ??
Originally Posted by rrtbusa
Originally Posted by budz
My advice, keep the box and slip around for a couple weeks.....Both drives are very good, but have unusually high rates of early failure. I think Plextor 716's are beyond that now (been quiet lately). The 1640 hasn't shown the issues that continue to plague the 1620's.
As budz said, cdfreaks.com has some good information on their forums.
NEC AD-5170A Questions
By urb1972 in forum DVD & Blu-ray WritersReplies: 1Last Post: 24th Nov 2007, 20:39 -
NEC DVD burners
By RapidRio in forum DVD & Blu-ray WritersReplies: 6Last Post: 6th Jul 2007, 21:07 -
NEC DVD Drives
By RapidRio in forum Newbie / General discussionsReplies: 1Last Post: 5th Jul 2007, 13:13 -
NEC 4571A problem
By rmorrison1 in forum DVD & Blu-ray WritersReplies: 18Last Post: 1st Jul 2007, 12:35 -
NEC NDH81
By babagoi in forum DVD & Blu-ray RecordersReplies: 0Last Post: 24th Jun 2007, 19:05
