Hi Guys,
well I have a HP 9140i Cd writer....whenever I burn a Movie Cd using the HP CD writer software provided with the CD writer..I find that the Complete Movie has Burned on the CD...BUT this VCD Doesnt play On ANY conventional VCD Player....
.....I fail to understand the reason behind this ......can Any body help me Explaining which SOFTWARE I should use to burn my Movie VCD's So that I can Play it on ALL VCD Players....
......Any help is most Welcome........
Reagards,
Nityanand.
Hi, There
Have you tried to burn the VCD using Nero (VCD Option) I use it all the time and it works perfect.
I haven't try any other software to burn VCDs never had the need.
! Viva Mexico ! -
Do you select the VCD template in the burner software? You cannot just burn the file and make a CD-ROM with the movie on it. A VCD is formated and stuctured is a special way only used for VCD's. Nero is the most common VCD burner software. It has burning templates for VCD and SVCD creation.
</BLOCKQUOTE></FONT></TD></TR><TR><TD><HR size=1 color=black></TD></TR></TABLE>
You have to have that option in the burning software in order to create a VCD, you can't just drop the file and burn it as a data cd. Yes, it needs a special structure, check the "how to author VCD" Guide, to your left.
! Viva Mexico !
video doesn't play right in many players
By charlieship in forum Newbie / General discussionsReplies: 2Last Post: 30th Jun 2011, 00:02 -
Aiwa HV-MX100 display doesn't light up & stop button doesn't work
By TurboJoe in forum Newbie / General discussionsReplies: 15Last Post: 12th Feb 2011, 18:07 -
mpg with sound that doesn't play
By sivodsi in forum Newbie / General discussionsReplies: 3Last Post: 13th Jan 2010, 08:38 -
BSOD - Window doesn't load normal/safe mode
By hoon88 in forum ComputerReplies: 21Last Post: 25th Oct 2009, 07:49 -
PAL to NTSC..FAVSC doesn't work anymore and BeSweet Doesn't give me some op
By sandman423 in forum Video ConversionReplies: 13Last Post: 11th Mar 2008, 05:58
