does anyone have filters that they llike to use on naruto episodes?
Results 421 to 450 of 481
@hddvd2
thanks! that worked nicely!
sorry, but one more problem: no audio is extracted from episode 21. i have this line in my batch file:
however, it will only run for 1 second and stop there. the output would be 00:00 minutes long. what else can i do?
also, i still can't figure out why the background songs are so loud, louder than the voices. all i can hear in the intro and outro songs are the instruments, not the people singing. -
Still looking for help here, please. Anyone trying to convert the New Gaiking episodes?
I've found that removing the last line in the AVS file lets it play in media player classic with no lag in the sound, however, it still errors out after converting. I tried using WinAvi converter to convert the AVS file, but it comes out with a delay in the sound, so it falls behind the video almost immediately.
From using mediainfo, the audio codecs are the same as all the other videos I've converted:
for example:
Bleach - 64.avi
MPEG1/2 L3 128Kbps 48KHz 2 channel
Codec : XviD
Bit rate : 828 Kbps
Width : 640
Height : 480
Aspect ratio : 4/3
Frame rate : 23.98
Bits/(Pixel*Frame) : 0.112
then Gaiking - 01.avi
Codec : XviD
Bit rate : 1145 Kbps
Width : 704
Height : 396
Aspect ratio : 16/9
Frame rate : 23.98
Bits/(Pixel*Frame) : 0.171
Ideas? Suggestions? -
Everytime I run my .bat file it says it was succesful but the only folders and files I have are encodedvideo/batch and mainencoding.bat which only contains...
Bat FileCode:::MAIN ENCODING BATCH @echo off
My directory structure is like this...Code:::QUENC Encoding Batch Generator! @echo off :::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::: :: Lines beginning with 2 colons are comment line. They are ignored,:: :: so you can safely copy this. :: :: Change the value after the equal sign :: :::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::: :: Pulldown file? (yes if your videos are 23.976fps, no if your videos are 29.970fps) @set applypulldown=yes :: Resize type (Bicubic, Lanczos, Lanczos4). @set resize=Lanczos4 :: Resize Value (Fullscreen is 660, 440 - Widescreen is 660, 330) @set width=660 @set height=440 :: AddBorders Value (Fullscreen is 20, 30 - Widescreen is 75, 30) @set topbottom=20 @set leftright=30 :: Audio Bitrate (The one you chose when calculating) @set audiobitrate=192 :: Path for source videos (The video you want to encode should reside in there) @set sourcevideo=C:\MonsterDVD\1 :: Video Bitrate (The Bitrate calculated in step 2) @set bitrate=3000 :: Path to your encoder. Select QUENC.exe @set quenc=C:\QuEnc\QuEnc.exe :: Path for DVD2SVCD (The folder where DVD2SVCD is located) @set dvd2svcd=C:\Program Files\DVD2SVCD :::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::: :: DO NOT CHANGE ANYTHING BELOW UNLESS YOU KNOW WHAT YOU'RE DOING!! :: :::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::: :: Define variable path for programs that is included with DVD2SVCD @set besweetdir=%dvd2svcd%\besweet @set besweetexe=%besweetdir%\besweet.exe @set pulldown=%dvd2svcd%\pulldown\pulldown.exe @set mplex=%dvd2svcd%\dvdauthor\mplex.exe @set encodedvideo=%sourcevideo%\EncodedVideo echo Generating Batch, tutututut - please be patient. echo ::MAIN ENCODING BATCH > mainencoding.bat echo @echo off >> mainencoding.bat MKDIR %encodedvideo%\Batch for %%x in (*.avi) do ( echo.AVISource^("%sourcevideo%\%%x"^) echo.%resize%Resize^(%width%,%height%^) echo.AddBorders^(%leftright%,%topbottom%,%leftright%,%topbottom%^) echo.ConvertToYV12^(^) ) > "%%~nx.avs" if %applypulldown%==yes ( for %%x in (*.avi) do ( echo."%quenc%" -i "%encodedvideo%\%%~nx.avs" -o "%encodedvideo%\%%~nx.m2v" -b %bitrate% -maxbitrate 8000 -dc 10 -2 -mpeg2 -hq -vbr -noscene -nocgop -interlaced -gopsize 12 -maxbframes 2 -aspectratio 4:3 -mpeg2mux noaudio -auto -close echo."%pulldown%" "%encodedvideo%\%%~nx.m2v" "%encodedvideo%\encoded%%~nx.m2v" -run -exit echo."%besweetexe%" -core^( -input "%sourcevideo%\%%~nx.avi" -output "%encodedvideo%\%%~nx.mp2" -logfilea "%besweetdir%\BeSweet.log" ^) -ssrc^( --rate 48000 ^) -toolame^( -m s -b %audiobitrate% ^) echo."%mplex%" -f 8 -o "%encodedvideo%\%%~nx.mpg" "%encodedvideo%\encoded%%~nx.m2v" "%encodedvideo%\%%~nx.mp2" echo.DEL "%encodedvideo%\%%~nx.m2v" ) > "batch_for_%%~nx.bat" ) ELSE ( for %%x in (*.avi) do ( echo."%quenc%" -i "%encodedvideo%\%%~nx.avs" -o "%encodedvideo%\%%~nx.m2v" -b %bitrate% -maxbitrate 8000 -dc 10 -2 -mpeg2 -hq -vbr -noscene -nocgop -interlaced -gopsize 12 -maxbframes 2 -aspectratio 4:3 -mpeg2mux noaudio -auto -close echo."%besweetexe%" -core^( -input "%sourcevideo%\%%~nx.avi" -output "%encodedvideo%\%%~nx.mp2" -logfilea "%besweetdir%\BeSweet.log" ^) -ssrc^( --rate 48000 ^) -toolame^( -m s -b %audiobitrate% ^) echo."%mplex%" -f 8 -o "%encodedvideo%\%%~nx.mpg" "%encodedvideo%\%%~nx.m2v" "%encodedvideo%\%%~nx.mp2" ) > "batch_for_%%~nx.bat" ) for %%x in (*.avi) do ( echo.CALL "%encodedvideo%\batch\batch_for_%%~nx.bat" ) >> mainencoding.bat for %%x in (*.avi) do ( MOVE "%sourcevideo%\%%~nx.avs" "%encodedvideo%" MOVE "batch_for_%%~nx.bat" "%encodedvideo%\batch" ) move "mainencoding.bat" "%encodedvideo%\batch" echo. echo. echo. echo. echo Batch Creation Finished! hehe - Now you just have to open MainEncoding.bat !! pause :::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::: :: END OF BATCH :: ::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::
C:\MonsterDVD\1\Monster04.avi
C:\MonsterDVD\1\Monster05.avi
etc.
Any help? -
Darn it, it's taken me two months to get my stuff back and I finally got to the actual encoding. However, when I hit mainencoding, it encodes to 12% then stops..I'm frustrated and haven't a clue what to do. Does anyone know this is happening?
Given that little information, I don't think anyone can help you much. Scanned the source for errors in virtualdub ? Perhaps a GSpot of your source file to see if one of he experts here can spot something about your source ?Originally Posted by TyrantusIf in doubt, Google it.
This help any?
http://img454.imageshack.us/img454/3081/untitledhelp28ms.png
As there really isn't much else to say, as I hit the mainencoding and it starts to encode then stops at 12%. I gave it some time but it just stayed there. I tried encoding them individually and same thing: stopped at 12%. -
this is for p1noypr1de. i used to have this same exact problem. please post your batch. i dont remember how i fixed it but i will try. also i am not using this method anymore. i use a program called AutoQ2. It is fast as hell (1-pass VBR) and the quality is about the same or better than multipass vbr. you should give it a try. it also does batch so u can encode a lot of episodes. i have finished episodes 1-129 in about 2 months with breaks. Here is the link to AutoQ2: http://home.arcor.de/autoq2_amsoft/files/AQ2_120306_1135.7z.
Thanks to the creator of AutoQ2 (Amnon82). -
i forgot to tell u what AutoQ does. it predicts the right Q for the episode or movie. You just put in the size u want and it will do the rest. give it a try. you wont be dissapointed.
and to Tyrantus i alos had that same exact error. but now i dont remember how to fix it anymore. lol. if only you guys posted while i was still using this method.
Ah, darn. Any clue at all? Will I have to start over or is it some minor thing? Man, two months later and I still screw up. I amaze myself...Originally Posted by hddvd2
Ah ok. I'm still new to this, so if this is the wrong thing posted, I apologize for that.
Sample Batch:
MainEncoding Sample:"C:\Program Files\cct2t.exe " -t "Naruto4980" "C:\AviSource\EncodedVideo\[ANBU-AonE]_Naruto_01_[ED304340].avs" -batch
MOVE "C:\AviSource\EncodedVideo\batch\[ANBU-AonE]_Naruto_01_[ED304340].mpv" "C:\AviSource\EncodedVideo"
REN "C:\AviSource\EncodedVideo\[ANBU-AonE]_Naruto_01_[ED304340].mpv" "[ANBU-AonE]_Naruto_01_[ED304340].m2v"
"C:\Program Files\DVD2SVCD\DVD2SVCD.exe\pulldown\pulldown.exe" "C:\AviSource\EncodedVideo\[ANBU-AonE]_Naruto_01_[ED304340].m2v" "C:\AviSource\EncodedVideo\encoded[ANBU-AonE]_Naruto_01_[ED304340].m2v" -run -exit
"C:\Program Files\DVD2SVCD\DVD2SVCD.exe\besweet\besweet.exe" -core( -input "C:\AviSource\[ANBU-AonE]_Naruto_01_[ED304340].avi" -output "C:\AviSource\EncodedVideo\[ANBU-AonE]_Naruto_01_[ED304340].mp2" -logfilea "C:\Program Files\DVD2SVCD\DVD2SVCD.exe\besweet\BeSweet.log" ) -ssrc( --rate 48000 ) -toolame( -m s -b 128 )
"C:\Program Files\DVD2SVCD\DVD2SVCD.exe\dvdauthor\mplex.exe" -f 8 -o "C:\AviSource\EncodedVideo\[ANBU-AonE]_Naruto_01_[ED304340].mpg" "C:\AviSource\EncodedVideo\encoded[ANBU-AonE]_Naruto_01_[ED304340].m2v" "C:\AviSource\EncodedVideo\[ANBU-AonE]_Naruto_01_[ED304340].mp2"
DEL "C:\AviSource\EncodedVideo\[ANBU-AonE]_Naruto_01_[ED304340].m2v"
If this doesn't help you out, I'll try uninstalling CCE and try again...though I recently just installed it. (Trial ran out)::MAIN ENCODING BATCH
@echo off
CALL "C:\AviSource\EncodedVideo\batch\batch_for_[ANBU-AonE]_Naruto_01_[ED304340].bat"
CALL "C:\AviSource\EncodedVideo\batch\batch_for_[ANBU-AonE]_Naruto_02_[F40F1F44].bat"
CALL "C:\AviSource\EncodedVideo\batch\batch_for_[ANBU-AonE]_Naruto_03_[382210C3].bat"
CALL "C:\AviSource\EncodedVideo\batch\batch_for_[ANBU-AonE]_Naruto_04_[2943B5D1].bat"
CALL "C:\AviSource\EncodedVideo\batch\batch_for_[ANBU-AonE]_Naruto_05_[C2DD44FB].bat" -
I'm not sure that this is above-board or legal. If the manufacturers of software allow a free trial, I'd assume they would only want you to try it once. However, I'm not sure, so I will not issue a formal warning. Please do not advocate activities of this kind, and if you use CCE that much you should buy it. Please consider this an informal warning.Originally Posted by Tyrantus
Many thanks,
Cobra -
Any you have in mind? I really am new to this and I hope it's not because of something I did. So, just to confirm, my batches and codes looked fine, just something unexplainable then? And if I need to get another encoder, any free ones to try for now, as I want to make sure I can learn how to do this right before I buy anything.
the AVS files should stay AVS but u should have ended up with a MPEG file.
Awesome. I got it to finally encode but the audio and videos didn't merge. Can anyone tell me how to merge them?
Never mind I went searching and found the answer, sorry if I pissed anyone off.
Hey guys,
I hate to bug everyone again. But I am still waiting on the answer to my post about having 2 episodes that I was trying to encode that are at 119 frames per sec. I was just wandering if there is a way to get these down to 23.976 like there supposed to be?
---->Same as the post before I got it figured out. Sorry about that. -
Argh, I've kept trying but I still can't the encoding to work with Quenc...
My video and audio don't merge, and I also have these M2V files in the same folder with them. Can anyone please tell me what to do next, as I'm nearly finished I believe, but I just don't know how to merge anything. -
okay ive tryed to use both the ffmpeg and quence tutorials and i am having a problem with both.
The ffmpeg is my prefered conversion because it is quicker but when i try to import the converted episode into DVD Author it says that the bitrate is 104857 kbps and that the max is 9800... All i did was copy and paste the code as it did not have to be changed until later episodes.
Although quenc does work it takes like 1 hr each... which i would prefer not to have to do but if it is a last resort then okay BUT it will not convert all episodes... when i open "batch_for_..." it will open the video conversion then stop immediately and begin converting the sound... This also happens with ffmpeg occasionally... It also seems to be tempremental and on a rare occasion will convert or not convert??? Any help would be much appreiciated.
Azrael-Kun
How to convert matroska MKV to AVI or OGM to AVI
By Baldrick in forum User guidesReplies: 211Last Post: 13th Apr 2012, 01:56 -
Batch convert mkv to avi possible?
By dude112 in forum Video ConversionReplies: 5Last Post: 6th Jul 2010, 03:56 -
Need a Program to convert avi/mkv/ogm to dvd that is free for winxp
By animefanx in forum Newbie / General discussionsReplies: 1Last Post: 30th Aug 2009, 04:22 -
HOW-TO - CONVERT AVI, OGM or MKV to DVD
By Ecko_Blue in forum User guidesReplies: 44Last Post: 19th Sep 2008, 10:10 -
batch convert mkv to avi
By projecttemp in forum Video ConversionReplies: 7Last Post: 14th May 2008, 07:19
