I am using both TMPGENC 2.5 and TMPGENC 3.0 Xpress, and the I am getting the same results. I am trying to convert some anime files, but everytime the frame changes, there are little glitches, like little boxes all over the screen that show up for a split second, then go away. I am trying to figure out if it is the anime files or the encoder, but when I play the anime files on my computer (using WMP) they play fine.
All help regarding this problem is greatly appreciated
Thanks,
Dain
[img]vba02cbbfe6.gif[/img]
Squares ? That's called Macro Blocks or Block Noise. Usually due to too low an encode bit rate. Increase your bit rate and re-encode.
Ok ill try that, its just weird though because im using the same rate ive done on all other anime files...maybe its just this particular one.
THANKS tho that sounds like a winner[img]vba02cbbfe6.gif[/img] -
Are you encoding to DVD Specs ? If that's the case, you can't go above 9800 kbps- and keep it around 8500 just to be safe.
well soopafresh, I upped the bit rate and its still doing the little squares on the screen. Is there anything else I can try?
Pegasys released TMPGEnc Video Mastering Works 5 (aka TMPGEnc 5.0 XPress)
By roma_turok in forum Latest Video NewsReplies: 6Last Post: 24th Jun 2011, 16:42 -
TMPGEnc to License x264 Encoder for TMPGEnc 4.0 XPress
By poisondeathray in forum Latest Video NewsReplies: 17Last Post: 28th Jan 2011, 16:07 -
TMPGenc DVD Author 3 will not open file from TMPGenc Xpress 4.0
By artyjeffrey in forum Authoring (DVD)Replies: 4Last Post: 8th Nov 2008, 14:23 -
BIG Problem TMPGENC Xpress V.4.4.1.237 + TMPGEnc DVD Author ver.3.1.2.176
By milindb1 in forum Authoring (DVD)Replies: 1Last Post: 20th Aug 2008, 03:41 -
difference btw.TMPGEnc 4.0 XPress and TMPGEnc DVD Author 3 with DivX Auth??
By geronemo in forum Authoring (DVD)Replies: 5Last Post: 18th Nov 2007, 16:07
