just a quick question...
do all DDR motherboards support regular sdrams as well?? for eg... an epox 8KHA+ ??
Thanks~! ^^
I dont know about ALL, I would say the majority do, because they are manufactured with the intent that they some consumers arent quick to upgrade unless they have to & the often flucuation in memory prices.
Go here
http://www.ocworkbench.com/hardware/epox/8kha/8khap2.htm
Besides,with DDR Memory,just ditch the sdram and buy the DDR.I saw a 256MB DDR stick at http://www.tigerdirect.com for like $40 .
Sorry, Kdiddy, but not true at all:
DDRAM (Double Data Ram) evolved from SDRAM as a cost-effective alternative to Rambus memory, which is used in Pentium 4-based workstations. As with Ultra160 SCSI, DDRAM provides two data accesses per clock cycle by utilizing both the upward and downward signal slopes. To implement this scheme, a DDR DIMM module requires 184 pins rather than the 168 pins that mark SDRAM. As a result, the two types of memory are not interchangeable.
Some motherboards have slots for both, but if you have a DDR motherboard, you can't use standard PC100/PC133 memory.
"As a result, the two types of memory are not interchangeable.
Some motherboards have slots for both, but if you have a DDR motherboard, you can't use standard PC100/PC133 memory. "
Yet again, another poster who did NOT comprehend the question before deciding to post. The question was NOT can you use both types of memory at the same time, NOR was the question will DDR fit in SDRAM memory slots. HOWEVER, the question was do most "motherboards that are DDR capable, have SDRAM capability as well" to which the answer is yes. Now the board in question DOES NOT, but there are many boards that do. So again, before you jump and tell somebody that they are "not true", please read & comprehend the entire post.
Our motherboards with DTS virtual surround sound my only choice?
By MarcMiller in forum Newbie / General discussionsReplies: 1Last Post: 3rd Nov 2011, 11:30 -
Disadvantages of motherboards with onboard graphics?
By A Traveller in forum ComputerReplies: 2Last Post: 13th Jun 2011, 15:12 -
DDR and DDR2
By Jomapil in forum ComputerReplies: 3Last Post: 18th Dec 2008, 07:50 -
DDR vs DDR2
By CSULB71 in forum ComputerReplies: 2Last Post: 1st Jun 2008, 14:54 -
nVidia 6150 motherboards and HDTV
By Robert Simandl in forum Media Center PC / MediaCentersReplies: 13Last Post: 14th May 2007, 15:11
