I want to make copy of DVD but that DVD I can't make copy so I used DVD Decrpter during process one file couldn' read so I deleted and operation successfully finished then I used DVD shrink becase file size was 6 GB but now DVD shink can't start and give error message like VOB 4 file can't read so I am confuse what to do?
Sounds like you deleted a needed file when you used DVD Decrypter. If the DVD will not rip properly in DVD Shrink or DVD Decrypter, try ripping with DVD Fab Decrypter. This has done the trick for me when Shrink and DDecrypter have failed.
While you are at it give Iso Buster a try. No promises but worth 5 min's if you are still not having any luck with that one .vob. It may also be worth setting DVD Decryptor to "aggressive mode" - may help and can't hurt
I tried DVD FAB but some how VOB 3 file cant read and stuck but I reinsert dvd and it work then I tried dvd shrink to minimize file from 6 GB to 4 GB and get error mesage like VOB 3 file corrupted so it didn't let me I think on my dvd scratch causing problem or something else Is that any other software available to reduce file size besides DVD SHRINKOriginally Posted by RowMan
You are right - it probably is a problem with the disk (more than likely a scratch) and so your best best is to try and extract this problem VOB. As I suggested earlier try Isobuster. Not a guarantee but it often extracts VOBs where others fail. DVD Shrink isn't the problem.Originally Posted by Neil_2004
- e404pnf
EDIT: Also, did you try DVD Decrypter in aggressive mode?
Lipsync-problem with copy of authored DVD (TMPG-related)
By fedet123 in forum Authoring (DVD)Replies: 2Last Post: 10th Oct 2009, 19:01 -
Is copy Sony PSP game same as copy DVD disc?
By coody in forum ComputerReplies: 10Last Post: 15th Dec 2008, 07:26 -
Help, Problem with Intervideo dvd copy 5 platinum
By heman28 in forum DVD RippingReplies: 2Last Post: 3rd Jan 2008, 20:12 -
Power DVD Copy Problem
By Tel in forum Authoring (DVD)Replies: 3Last Post: 8th Aug 2007, 16:51 -
dvd copy problem
By ht0160 in forum DVD RippingReplies: 10Last Post: 1st Jul 2007, 17:31
