Are there any web sites that provide free transitions or templates for Ulead Movie Studio? Also, I'm using version 8 and I'm considering springing for version 9. Are there many significant differences between the two versions? Thank you!
Originally Posted by stockcerts
It's my understanding that VS9 made some significant improvements over 8. For one thing VS8 users were having a lot of sync issues that went away in 9. It now includes native AC3 support. There's quite a few improvements to the editing features as well, defintely worth a look. -
thecoalman is right. The principle in this guide should be essentially the same for VS menu templates as well.
To import menu templates from other Ulead authoring apps, such as DVD MovieFactory (or even DVD Workshop), look in Program Files | Ulead Systems | Ulead DVD MovieFactory xx | Template | xx, and select one or all of the .UFO files you find there, then copy them to your target Ulead program in the same corresponding folder.
You might also try installing the previous versions of MovieFactory, 2 and 3, if you can manage to get you hands on them, then download and intall the free extra templates from Ulead, then copy those .UFO menu template files into your current Ulead VS version. That's a lot of free extra templates!
Does anyone sell Sony Vegas Movie Studio templates
By sdsumike619 in forum EditingReplies: 5Last Post: 7th Jan 2012, 12:43 -
Ulead Video Studio 11 - how to add multiple sub and more movie clip
By mic2x in forum SubtitleReplies: 0Last Post: 27th Aug 2008, 12:52 -
Sony Vegas Movie Studio/DVD Architect Studio
By DJL82 in forum EditingReplies: 8Last Post: 1st Feb 2008, 15:14 -
PINNACLE STUDIO 11 vs. SONY VEGAS MOVIE STUDIO 8
By coody in forum Capturing and VCRReplies: 4Last Post: 26th Nov 2007, 18:53 -
Ulead Video Studio 7 SE
By uricktam in forum Newbie / General discussionsReplies: 1Last Post: 10th May 2007, 11:14
