I'm just wondering if when the new Blu-Ray format comes out (or it's competitor) if we will be shooting ourselves in the foot for converting VHS to current DVD-/+Rs.
For example, will we be able to get better results using Blu-Ray - more genuine, archival quality transfers from VHS to DVD? Or is it more of a analog>digital conversion issue that will not be resolved by simply allowing more storage space?
i.e. is a current VHS to DVD-R transfer done today pretty much the best I can do given the limitations of the conversion process? Or will Blu-Ray give us archival quality copies and make me wish I could redo them all?
Thanks for any feedback you can offer.
-DVD-Dude
Results 1 to 15 of 15
Hi,
Whats the max capture cards can do today??? 15mbps????? If so than you'd be able to capture more at the MAXIMUM data rate to get the most without sacrificing quality. BUT you still can't get better quality than the video source. I think there is some realistic limit of what you'd capture at. Besides Disc space on your pc/mac would be another limitation. Unless you have a few 200gb drives capping hours at max bitrate would really take up a ton of space for debatable quality improvement.
Bluray won't do anything for tapes.
Hi,Originally Posted by lordsmurf
Well it won't improve quality but could you imagine fitting vcd on a nextgen disc???
You could fit a few days worth at vcd level
kevinDonatello - The Shredder? Michelangelo - Maybe all that hardware is for making coleslaw? -
That's a good point.... the upside is I could consolodate what I have converted of old home movies onto a few discs!
However, does anyone know what the data transfer rate of blu-ray is supposed to be? Will the Blu-Ray DVD format still use MPEG2 compression? If so it seems like it wouldn't make a difference in quality... I see very little difference between SP and XP when coming from a VHS source to a DVD recorder... I assume SP is somewhere around 6 mbps, and XP is around 8. So if the codec is what limits the resolution I guess you could make it 100 mbps and it wouldn't matter. Am I right in making this assumption? I'm just trying to understand if there is or isn't a difference in quality and why that might be.
Thanks again!
-DVD-Dude -
Hi,
I assume its very similar for blu-ray. It looks like its a hybrid mpeg2 since its meant to operate at higher highdef resolutions than the 720x480 current dvd standard.Originally Posted by videohelp.com glossary
mpeg2,vc-1 and h264 compression.
up to 36 mbit/s.
http://en.wikipedia.org/wiki/BluRay -
I would disagree. I have tried recording analog sources to mini DV tape. At 25 mbps, I saw none of the MPEG2 artifacts that are so prevalent even at 8mbps. The miniDV copy was as good as the source. This leads me to believe that it should be possible to record VHS, SVHS, etc. to a higher bitrate format with significantly better quality than DVD captures are providing today.Originally Posted by dvd-dude
so this is gonna be another war for standardship ......there's the DVD Alliance vs the DVD Forum (+ vs -) Now there's Blue Ray vs HD DVD.
"Here We Go Again "
Thank god i still have my VHS tapes in the attic.
I would love to see the prices on them babies. -
What about lines of resolution? Is that another limiting factor in this process? If a DVD already has far more than a VHS but that doesn't resolve the issue I'm guessing a Blu-Ray with HD definition still won't do us any good from VHS.
I guess it all comes down to whether or not Blu-Ray will provide high bit rates that would compensate for the artifacts you can get when transferring older VHS tapes to DVD. Does anyone know for sure if this is true?
Thanks for the discussion... this is helping a lot!
-DVD-Dude -
Hi,Originally Posted by dvd-dude
Reread davidecks post:
At least his experience says a higher bitrate will help smooth out compression blockiness.I would disagree. I have tried recording analog sources to mini DV tape. At 25 mbps, I saw none of the MPEG2 artifacts that are so prevalent even at 8mbps. The miniDV copy was as good as the source. This leads me to believe that it should be possible to record VHS, SVHS, etc. to a higher bitrate format with significantly better quality than DVD captures are providing today.
If you use 9000k MPEG-2 and get blocks, your encoding methods are flawed.
VHS transfers on my dvd recorder yield no blocks on XP mode (8700 average bitrate), and visible (though few) blocks on SP mode (4220 average bitrate). Other than the blocks, which are few and far between, I am actually amazed that even by halving the bitrate the video comes out virtually identical to the one at 8700, to my eyes. Even for those extra special tapes, you wonder if it makes any sense to capture ONLY 1 hour on a dvd, rather than two.
Are you basing your results from your vhs to dvd (via dvd recorder)
from your pc monitor, or tv set ??
To date, there are no hardware dvd recorders that implement any
kind of IVTC in the recording stage. That is such an impact to
quality. If there were such a feature, *then* and *only then*
would a dvd recorder be the final frontier to the one-button
does it all, *and* produces fanstastic (like-original) source quality
if from a Film relm.
Until then, you'll almost always have macroblocks or MB's (pixelation)
in your dvd recorder vob's.
DVD Recorders record the full 29.970 fps (be it Telecine; Progressive;
or Interlace) source. It does not record the source as 23.976 fps
to the vob's when the given source is Film (aka, Telecine) nor does it
re-Telecine/IVTC during the recording stage. It simply records the
original 29.970 fps, and that is all
So, because it is encoding these interlace areas, you will see the MB 's
especially in these fields, and the finished vob's will be 29.970 fps,
and dvd2avi will read these vob's as Interlace (or in some cases, and
depending on dvd recorder) will see dvd2avi's window report as:
PPP II; PPP II; PPP II;
This is how dvd2avi would report, if you were to encode an MPEG and
run it through pulldown.exe, for an IVTC and report as Film / Progressive,
..as most Commercial DVD movies do
-vhelp 3448
VHS to Hard drive and blu ray?
By david151 in forum Capturing and VCRReplies: 14Last Post: 22nd Mar 2012, 11:44 -
Digital VHS to blu ray
By mobie29 in forum Authoring (Blu-ray)Replies: 1Last Post: 7th Apr 2011, 08:46 -
What is the difference between a Netwrok Blu-ray and Blu-ray DVD player?
By coody in forum DVD & Blu-ray PlayersReplies: 1Last Post: 4th Sep 2010, 23:04 -
Is it too much trouble to make Blu-Ray copies?
By timmus in forum Newbie / General discussionsReplies: 3Last Post: 20th Jan 2009, 04:53 -
Can I rip Blu Ray Discs with LG Super Multi Blu-ray Disc and HD DVD-ROM Dri
By donpato in forum Blu-ray RippingReplies: 5Last Post: 5th May 2008, 17:05
