Short version: How do you find a cell's precise length (to 3 or 4 decimal points)?
Long version: I'm having a sync issue with GK caused by a cell with no audio. The cell is at the beginnig of a PGC I'm trying to rip and has no audio. The audio stream starts at the second cell with a delay of 0ms. When I try to rip using GK, it will demux the audio stream with delay of 0ms and mux it to the video beginning with cell 1. So the audio will start prematurely and be out of sync for the exact length of cell #1. What I need to do is get the audio to start when cell 2 starts in the avi file. So I think I need to find the exact length of cell 1 so that I can delay the audio track by that length. I need to keep the cell (a warning screen) so just dumping it entirely by deselecting it in DVDDecrypter is not an option. But ANY other suggestions on how to deal with this are welcome!
VFR - Video Length Issue
By olcifaraga in forum EditingReplies: 0Last Post: 26th Apr 2012, 02:01 -
NTSC/PAL but exact film length: How so?
By Anonymous5394 in forum Newbie / General discussionsReplies: 2Last Post: 5th Mar 2010, 11:42 -
How to find out the length of the clips
By brandox in forum Newbie / General discussionsReplies: 6Last Post: 29th Aug 2009, 00:07 -
How to find the exact parameters used to encode a video
By SoupNazi83 in forum Video ConversionReplies: 4Last Post: 18th Jul 2008, 19:10 -
How to find out Frame Rate and Video Length
By GSReddy in forum ProgrammingReplies: 0Last Post: 20th May 2008, 00:02
