Ok, I've tried everying!
I'm trying to cap at 29.97 at 640x480 with a USB 'AlterTV' device.
I've disabled all previews, made sure DMA is on, rebooted and turned off all other apps. I'm running a 1.2 gig Athalon with a gig of ram and VD reports that my proc during cap isn't being pushed past 50%.
I've got plenty of HD space and using Huffy (oh and Win2k) but I still only capture just over 29 fps, so my resulting files are very choppy.
Any suggestions?
Mojo
The Huffyuv codec is very bad at playback, but it doesn't necessarily mean anything is wrong with the video. It is popular as a lossless intermediary to be encoded to another format. Try encoding a part of your video to MPEG and you'll probably be pleasantly surprised.
I tried what you suggested, but the MPEG played back equally as choppy.
My frame rate averaged around 29.2.
One thing I don't understand - is the framerate actually changing constantly, as Virtual Dub displays during capture? Doesn't that make it more or less impossible to get smooth playback? I would think that, if it realized it couldn't cap at 29.97, it would pick (or suggest) a lower frame rate and stick to it.
Still, I don't know why I can't encode at 29.97. My CPU isn't being taxed. Also, when I pick another form of compression (like DiVX) the frame rate goes way down, to maybe 15.
Mojo
Upon re-reading, I noticed you are using a USB device...so my question is this: is it a USB 2.0 device? If not, I suspect your problem might be one of data rate. USB 1.0 can only handle about 12 Mbits/sec, which works out to about 1.5 MB/s. Huffyuv, on the other hand, produces a data rate of 6.5 MB/s when I use it to capture at 480x480, which is less than what you are attempting. I can't think of any other explanation, maybe someone else can help out here.
As for Divx, you really shouldn't use it for capturing - the level of processing required is extremely high, and doing it realtime will simply never produce very good results (also responsible for the substantial framerate drop).
Virtual dub
By santolina in forum Newbie / General discussionsReplies: 4Last Post: 22nd Jul 2009, 14:48 -
help with virtual dub
By Remyisme in forum Newbie / General discussionsReplies: 7Last Post: 30th Jan 2008, 16:36 -
Bit Rate And Frame Rate
By bharathi_n_r in forum Video ConversionReplies: 2Last Post: 30th Nov 2007, 06:48 -
Virtual Dub Mod
By OG24 in forum Newbie / General discussionsReplies: 11Last Post: 8th Aug 2007, 16:36 -
Frame rate conversion by changing frame count
By asmaa in forum Video ConversionReplies: 2Last Post: 1st Aug 2007, 11:15
