Hi
I created a DVD from two movies in DVD-Lab Pro
I made menu for the movies but when I burned the DVD I see only the first movie but I don't see the menu
Connections screen:
You are in breach of the forum rules and are being issued with a formal warning.
/ Moderator lordsmurf
Closed Thread
Right beside your connections window, there is a set of tools. The one that looks like a crosshair (this is the "draw end connection links" button), will allow you to draw the connection from the First Play function and the Title Button function to your root menu.
DVD Lab Pro Menu Resolutions
By Anonymous344 in forum Authoring (DVD)Replies: 0Last Post: 6th Dec 2010, 17:11 -
Need some Menu help from a DVD-lab PRO master
By jeanpave in forum Authoring (DVD)Replies: 13Last Post: 4th May 2010, 15:03 -
DVD Lab Pro menu help
By stantheman1976 in forum Authoring (DVD)Replies: 12Last Post: 27th Jan 2009, 17:27 -
DVD-Lab pro menu problem
By wackman in forum Authoring (DVD)Replies: 4Last Post: 26th Aug 2008, 04:52 -
Motion Menu on dvd lab pro 2
By djakaburo in forum Authoring (DVD)Replies: 1Last Post: 12th Apr 2008, 12:03
