Hi. I am trying to capture a few small segments from a DVD using Xilisoft's DVD Ripper. I have the DIVX 6.0 codec on my Win XP PC (3.0 proc, 1 gig ram, etc..). When I capture the segment the audio gets out of sync and I get an occasional pause or 'jerk' in the motion. The clip I'm working on is about 3 minutes. Has anyone had good luck with this product? The thing I like about it is you can preview the video and pick right where you want to capture and end the clip. Are there better codecs around to do this or is DIVX about the best quality? Or is there any better software? I know about DVD2AVI and Virtual DUB but I kind of like the interface and preview features of the Xilisoft product. Thanks in advance.![]()
you can preview with dvd2avi and virtualdub. select start and end and save. fairuse wizard is also easy to use.
Yeah. I just tried the Fairuse program and it seems to work great! About to buy the full version!!
Need help using Xilisoft Blu-Ray ripper
By billw6560 in forum Blu-ray RippingReplies: 10Last Post: 10th Sep 2013, 23:46 -
Xilisoft Blu Ray Ripper - Does Anybody Test This Program?
By devilcoelhodog in forum Blu-ray RippingReplies: 4Last Post: 24th Mar 2011, 14:03 -
Xilisoft Blu-Ray Ripper - Subtitles problem
By Mister Epic in forum Blu-ray RippingReplies: 1Last Post: 25th Oct 2009, 10:52 -
Xilisoft Ultimate DVD Ripper profiles question.
By mtdg in forum DVD RippingReplies: 3Last Post: 8th Jul 2009, 03:57 -
Xilisoft dvd ripper platinum and episodes
By surfer in forum DVD RippingReplies: 3Last Post: 1st Apr 2008, 03:59
