Well I use TMPGenc Xpress to convert and edit my videos, I love this program. But I'd like to know if there is a similar program that will give me more editing choices. I just want to find a similar program with more editing options!
maybe tmpgenc mpeg editor and see https://www.videohelp.com/tools?s=17#17
Thanks Baldrick, but I just realized that I wasn't very specific. I'm wanting a program that I can use to clean up the video and audio of svcd's when I encide them to dvd. TMPGenc works great for cleaning up and ajdusting the video, but not the audio. Also I'd like a program with more filters so I can fine tune the picture quality. Thank you very much again for your reply Though!!!!!!!
Hi leeer73,
Have a look through the "Tools" section - thre's loads of categories in there. You don't say what your source is, but VirtualDub is good for AVIs and may have the filters you want / need.
As for the audio, there's an audio section in the "Tools". One good (and free) one is Audacity, though there are others.There is some corner of a foreign field that is forever England: Telstra Stadium, Sydney, 22/11/2003.
Carpe diem.
If you're not living on the edge, you're taking up too much room. -
Daamon, Thanks for the info! I download alot of movies. I usually download svcd's, but I'd much prefer to download AVI's. The only problem I have with AVI's is that when I encode to dvd, I loose alot of picture quality. I use Cucusoft for that. If I were to use Virtualdub to encode my avi's to dvd's, will it be better as far as keeping the quality of the picture? Thanks for your help!
VirtualDub doesn't encode to DVD - it can use filters on the source AVI to produce a filtered AVI.
If you're worried about quality, and they're available, buy the original movies.There is some corner of a foreign field that is forever England: Telstra Stadium, Sydney, 22/11/2003.
Carpe diem.
You can use VirtualDub to clean the video up -- then frameserv to TMPGenc to convert it to MPEG2 for DVD. Good luck!
Thanks again Daamon.
Torrential, thanks for chiming in. Thats sonds good, I will definatlyey look into VirtualDub. I just dont think that TMPGenc Xpress can work with AVI's.
Which program I should use for video editing?
By Shigatsu in forum Newbie / General discussionsReplies: 3Last Post: 15th Jun 2011, 11:09 -
Best Editing Program
By deanmcdonagh in forum EditingReplies: 1Last Post: 9th Dec 2009, 09:21 -
Basic editing: which Mac program for my DVD editing situation?
By Nuevonik in forum MacReplies: 4Last Post: 8th Jan 2009, 07:06 -
The best program for editing?
By FredAstair in forum Newbie / General discussionsReplies: 21Last Post: 17th Dec 2008, 12:04 -
vidoe editing program
By romik91 in forum Video ConversionReplies: 15Last Post: 24th Aug 2007, 21:24
