You know how Nero Vision Express lets you lower the quality of the video so you can put more minutes of video on a DVD, how would I do that with DVD lab pro? I would use Nero, but it came bundled with my DVD player and I hate the preset menu formats.
I use VSO DivX to DVD to first convert from AVI and then import it in DVD lab pro. Would I lower the AVI's quality first, or after conversion? Or, I haven't found a way yet, but can I do this in DVD lab pro?
Thanks in advance.
use an converter where you can set the output size like tmpgenc, tmpgenc xpress. then you don't have to shrink with dvd-lab pro.
or author to hd with dvd-lab pro, ignore that it is too big. shrink it with dvd shrink.
How do I merge and compress VOB files?
By Mickie in forum Video ConversionReplies: 12Last Post: 23rd Jul 2011, 23:30 -
How to compress MPEG4 files for emailing?
By robinh in forum Newbie / General discussionsReplies: 1Last Post: 21st Oct 2010, 15:00 -
How to compress files?
By Takeonelastbreath in forum Newbie / General discussionsReplies: 7Last Post: 20th Sep 2010, 11:42 -
Compress some files
By alintatoc in forum ComputerReplies: 5Last Post: 24th Feb 2009, 04:14 -
Need to compress 5 VOB files to fit in one 4.7GB DVD...
By pmolson in forum Video ConversionReplies: 12Last Post: 20th Oct 2008, 17:52
