  1. Member lacywest's Avatar
    Aug 2001
    California
    I have been trying to use DVD Rebuilder to back up the movie Hide and Seek
    I use AnyDVD 5.2.7.1 and CloneDVD2 2.8.4.1 to do the ripping.
    I am keeping everything but the upcoming attractions. Plus I am keeping the DTS audio.
    When I do the shrinking with DVD Rebuilder and I'm using the current pro one .... I've done 9 passes ... 4 passes and 2 passes. Same results.
    When the little girl is in the bedroom of the last 3-5 minutes of the movie the movie is doing all kinds of wierd stuff.
    But if I do the shrinking with DVD Shrink 3.2 ... no problems.
    So what's up ... does DVD-Rebuilder ... need to fine tune some more to process ... Hide and Seek correctly ... or .... ???? .... What ??
  2. DVD Ninja budz's Avatar
    Jan 2003
    In the shadows.....
  3. The problem is that when you use DVD Shrink you loose the ILVU features... DVD Rebuilder keeps them... but that features still needs some fixes.
    My oppinions may change, but not the fact that I am right!
    www.rockassoftware.pt.vu
    DAudioK => https://forum.videohelp.com/viewtopic.php?t=306886
    DVD Rebuilder
    http://dvd-rb.dvd2go.org
    http://www.jdobbs.com
  4. ILVU, is that like for the multiple endings?
    Originally Posted by jagabo
  5. Member steptoe's Avatar
    Yes, DVD-RB Pro has only just been released with ILVU support, so is still being worked on to correct the problems with regards to ILVU that has shown to cause plenty of strange effects
  6. Originally Posted by stiltman
    Exactly... and Multi angles too
    DVD Rebuilder
  7. Member lacywest's Avatar
    Aug 2001
    California
    I didn't make any changes ... I just used DVDShrink instead of DVD-RB and DVDShrink ... did not mess up the multiple endings features.
