Hi,
I am in the process of converting some avi's to DVD using the said program, TMPGEnc but have some issues over some settings before I encode and lose the avi "captures" for good.
In the end, I hope to have two templates which I can use time and time again for my two distinct sources.
So let me begin by explaining my two sources:
Firstly, both are "captured" to computer using the Canopus ADVC-55 which is an Analogue to Digital Convertor connected to the PC via firewire.
Now, my first source is VHS - I use a JVC VCR with a TBC.
The second is live television from the digital sattelite service here in Britain, SKY+ (built in PVR, similar to Tivo in the States).
Both devices are connected to my A-to-D Convertor by an S-Video cable and Audio leads.
Once I have "captured" the footage on to the computer, I then need to encode it accordingly in TMPGEnc.
I have read Lordsmurf's excellent guide on DigitalFAQ.com but have a few questions on how I should be altering it for my sources as I believe he typically converts VHS anime.
The settings I am confused about are...
i) Resolution - I was up to date with the scene about a year ago so understood these settings back then but have now lost touch and I remember that half D1 (I think it was) came into question here.
Now with VHS, the source is already half D1 so it makes sense to leave it this way and select 352 x (rather than x 480 since I am in the UK and we use PAL).
But for my avi's from the Digital Sattelite, should I use the full resolution of 704 x or will half d1 again suffice - does it depend on how the broadcaster transmits it? How do I find this out?
ia) On a side note, what resolution do retail DVDs use and will the fact I use half D1 lead to any compatiability issues on any players or television - I guess I am curious to know how it fills the screen out?
ii) Maximum bitrate - I guess this leads on from the previous question. DigitalFAQ's guide uses CQ with a setting of 80 and a maximum bitrate of 4000 - If we determine that I should use full resolution for my sattelite footage, should I double this to 8000?
iia) Another side question, does using CQ and setting the maximum bitrate in this way guarantee that TMPGEnc will not create a file size greater than what is needed for DVD? If so, how does it take audio into consideration? And if I opt for VBR, what are the benefits? Will two passes suffice and how do I calculate what to use as the average bit rate as there is no automatic calculator in this version (but it has been introduced in TMPGEnc 3 XPress).
iib) Another question I have just come up with, does TMPG 3 Xpress have a CQ encoding setting exactly the same as this one?
iii) Again with DigitalFAQs guide, this time the advanced tab - I am guessing that all my source will be interlaced as most video is, including the television broadcasts - am I correct in this assumption?
But the field order, how do I know if its Top field first or Bottom down? By default, TMPGEnc selects Bottom down. What does this mean and which should I go for?
iv) The last question about video now, the Source Aspect Ratio, does it matter which 4:3 option I choose, e.g. just plain 4:3 or 4:3 PAL, etc.
v) The last question then, to do with audio - If I select PCM in TMPGEnc, does this mean I am not encoding the sound at all and consequently, this enables me to select the elementary streams and the later encode the audio with another program (to get AC3 sound) and use this in conjunction with the encoded video?
If this is the case, by doing so am I sacrificing video quality as it estimates bitrates and the space available on DVD-R expecting audio to remain PCM?
Sorry for the long winded post but I hope I have made myself clear and given the possibility to answer each section in turn to improve communication.
Thanks in advance.
Much appreciated.
TheGame7
TheGame7 - "I am 'The Game' because I am that damn good!"
I'm pretty sure there's a guide or methodology on this site for determining if your caps are interlaced or not.
I couldn't answer all questions, but if I do say so myself, I've done a bang-up job of answering most
Bear in mind that this is by no means the only way to do things, but I'd recommend that you look at this guide and possibly even this guide. If anything they might give you some tips about how to improve your process, and/or an insight into using a bitrate calculator and all the trials and tribulations of the ever-present "quality vs filling the disc up" conundrum that we all face.If in doubt, Google it. -
Thanks for all the info. You must have taken some time to compile that response and I thank you.
I have got hold of a working trial of TMPGEnc XPress now and was able to use VBR and its built in calculator makes things so much easier. Though it does take a hell of a long time - 10 hours for a 1-2 hour clip. I have motion estimate at the highest setting, by decreasing this will it make encoding a lot quicker?
Now I just have to work out how to find out if I should use top down or bottom up encoding. The new TMPEG does seem to go through some field order process at the start when adding the clip, but not sure if it automatically detects the right one.
As a matter of fact, the encoding which is in the 2nd hour of 10 right now was on bottom up by default but I changed it to top down thinking this is the norm.
Better cancel it, research and get it right first time to save a hell of a lot of time and dissapointment!
Anyone got a link to how to find out?
Thanks.
TheGame7TheGame7 - "I am 'The Game' because I am that damn good!" -
and that was just the first of three pages of an All-Forums search on "Determine Field Order"
Probably the easiest way is to use the Source Range function to isolate your footage down to a minute or so, so that you're only waiting about 5 minutes instead of 10 hoursIf in doubt, Google it. -
Sorry to bring this up again but have been following a guide in the guides forum about using TMPGEnc to convert AVI to DVD.
However, for the final stage of encoding settings, he states that for PAL we should select Progressive.
However, since the source is Interlaced (which I now know TMPGEnc Xpress automatically detects for me along with the field order!!) should I keep it this way?
Are most retail DVDs here in UK's PAL format Interlaced too?
And if I was to change it to progressive on this final settings screen, am I then to alter the filter settings for deinterlacing - usually better not used as quality detiriates..TheGame7 - "I am 'The Game' because I am that damn good!"
AVI to DVD MPEG (CCE or TMPGenc encoders)
By DJRumpy in forum User guidesReplies: 674Last Post: 15th Oct 2010, 07:46 -
Please Help with converting AC3 in an AVI to an AVI with MPEG-1/MPEG-2
By twin1701 in forum Newbie / General discussionsReplies: 4Last Post: 13th Jul 2010, 14:11 -
Strange problem between AVI(mpeg) file and DVD based on AVI(mpeg) file
By 1234567 in forum DVD RippingReplies: 49Last Post: 15th Feb 2009, 07:36 -
TMPGEnc Plus converts AVI to MV2 instead of MPEG movie
By buzzsaw in forum Newbie / General discussionsReplies: 4Last Post: 4th Feb 2009, 18:36 -
Tmpgenc dvd mpeg is not smart rendered by Nero
By perfection in forum Authoring (DVD)Replies: 3Last Post: 17th Dec 2008, 15:00
