I'm not sure where I went wrong - but I'm willing to redo the burn to fix it.
I took an 1.2gig avi and split into two files using virtualdub. Then I treated each 1/2 as a separate movie. I removed audio from both halves using Virtualdubmod as a .wav then, using ffmpeggui, I converted them to AC3. The video halves I encoded using TMPGenc (CBR). Then I remuxed using TDA.
Now, when playing, the first disk is fine..but the second..about 1/2 way thru the audio goes out of sync.
Any suggestions on how to redo? Maybe it was the source? But the above steps are how I do my other avi's ..and they turn out fine...
Thanks for any comments...
Not sure what you're suggesting here
I've never used Besweet before - is it better than ffmpeggui?Try muxing with TMPGenc
As for your last question - I would say it must go out of sync at some point, since all of a sudden, during a closeup you notice it and then it stays that way. After saying that, I'm wondering if there was a 'burp' during wav to ac3 - or at some point in the audio convertion ......do programs burp...? -
probably some problems when you splitted the avi. if it is mp3 vbr audio and you use audio->direct stream copy you will get problems.
Yes..it was mp3 audio. Whenever I use virtualdub I always set to 'direct stream copy'.
To avoid this happening in the future - can you point me to a guide where I can read up on how I should have done it?
Thanks...
audio sync problem, how to work out progressive audio sync delay
By jolt321 in forum Newbie / General discussionsReplies: 13Last Post: 10th Apr 2012, 21:09 -
An app to visually sync audio to video similar to Subtitle Edit visual sync
By cinesimon in forum AudioReplies: 3Last Post: 6th Sep 2011, 07:54 -
Audio out of sync after DVD authoring
By dexter30 in forum Authoring (DVD)Replies: 7Last Post: 29th Oct 2010, 18:27 -
Audio out of Sync with DVD Flick
By kawyboy in forum Video ConversionReplies: 1Last Post: 5th Apr 2010, 21:51 -
DVD to WMV - Audio out of sync.....Sometimes
By Number Six in forum DVD RippingReplies: 7Last Post: 14th Oct 2008, 19:19
