i am having a problem with connecting my PC to my TV ... i have TVTool 3.6 ... i am wanting to connect my PC & TV and show what i wanna watch on my TV, and work on my PC ... there is an opition for this in TVTool but i cannot get it to work ... has anyone got a better program to use, or are there advanced options i need to check and enable or disable ... please help i need it !!!
have you tried the change to tv-out with the nvidia display settings?
If you have the nVdida icon in your systray (bottom-right of screen), you can likely right-click it and get a menu to access settings. Otherwise, if you go Start > Control Panel > Display, nVidia cards usually add a tab in that box where you can change settings.
-abs"The purpose of art is not the release of a momentary ejection of adrenaline but rather the gradual, lifelong construction of a state of wonder and serenity." --Glenn Gould -
there is no nvidia icon in my systemtrey nor in the control panel > display ... i am not finding any of it ...
know anywhere where i can get a nvidia utlility to help me, or any others ?!!?!
cheers for the help too !
Connection help please
By Malissa in forum DVD & Blu-ray PlayersReplies: 1Last Post: 4th Dec 2011, 10:10 -
PC to TV Connection help
By mohit in forum Media Center PC / MediaCentersReplies: 5Last Post: 22nd Sep 2008, 16:15 -
By mohit in forum Video Streaming DownloadingReplies: 1Last Post: 21st Sep 2008, 11:03 -
PS3 Connection Problems
By Squid_uk in forum Off topicReplies: 2Last Post: 4th Sep 2008, 05:25 -
Problems with connection with my Panasonic HDTV and Timewaner HDTV box...
By S4one in forum DVB / IPTVReplies: 7Last Post: 2nd Nov 2007, 23:39
