I have some anime files that are in .ogm format. I want to put them all onto a DVD.
The .ogm files are around 360MB for a 40 min video, so I figure that the bitrate for the video and 2 audio files in the .ogm wrapper is around 1000 kbps, therefore the video bitrate must be less. The video format is 640 x 480 (according to WMP when I play the .ogg files in it).
I've demuxed the audio using virtualdubmod and will transcode the video streams to elementary video stream m2v using Tmpgenc, then author to a single disk, convering the .wav audio to AC3.
Given the low bitrate of the originals, will it make a difference if I transcode to full DVD or half D1? Or should I stick to full D1 because the originals are 640x480?
I also don't know if a higher bitrate will make a noticable quality difference -- if I burn to DVD5, my video bitrate will have to be around 2200 kbps (taking into account AC3 audio and some overhead for menus), if I burn to DVD9, bitrate could go up to 4500 kbps. Given that the orignals have such a low bitrate will I see a difference?
Final question. I'm planning to use 2-pass VBR in Tmpgenc. How close to the average bitrate will the actual bitrate be (ie, how conservative do I have to be in setting the bitrate in Tmpgenc?). I don't want to transcode all the stuff and find out I'm a little over the size limit for whatever my target disk size is.
Thanks for your help.
I'd go Full D1 - you'd be throwing away almost half your horizontal resolution if you used half D1, and by the sounds of the source, you need every bit of quality you can retain.Originally Posted by Nolonemo
Bitrates need to be taken in context of the codec used. For example, you generally need roughly 3-4x the bitrate of Xvid/DivX when using MPEG-2 to get a comparable quality. IMO 2200 would be really scraping the barrel for Full D1 - even Half D1 would probably struggle. 4500 might just be OK for Full D1 if using 2-pass VBR.Originally Posted by Nolonemo
I'd subtract 100 off whatever a bitrate calculator gives you. This should provide plenty of room for basic menus. If you want motion menus, then you're gonna need to take off more.Originally Posted by NolonemoIf in doubt, Google it.
Building a PC for Video Editing/Encoding - Need Advice plz!
By MaTTuP in forum ComputerReplies: 9Last Post: 6th Nov 2010, 11:37 -
Authored DVD exceeds DVD spec bitrate - advice needed.
By outerspacerace in forum Authoring (DVD)Replies: 27Last Post: 14th Jun 2008, 23:23 -
ADVICE needed plz! As of Feb 08, best format to ripp DVDs? TIA.
By carapalida in forum Newbie / General discussionsReplies: 3Last Post: 13th Feb 2008, 12:11 -
Need Advice for Video Conversion PLZ
By unknown7 in forum Video ConversionReplies: 4Last Post: 15th Jan 2008, 22:22 -
No audio on transcoded video
By evolker in forum ffmpegX general discussionReplies: 2Last Post: 24th Aug 2007, 22:08
