Hi all
Does Nero recognise VRO files?
I'm about to purchase a one of 2 DVD recorders:
Panasonic E55 or E85H.
If Nero can read these files than anything recorded onto RAM discs can then be edited on my PC using NERO. If not then I might have to get the E85H and do the editing via the hard disk. The E55 will be the cheaper option though (got Sky+ so another HDD not really necessary)
Thanks for you help.
S
VRO files are basically mpeg files (you can copy it to your PC and rename the extension to .mpg and it'll play in any media player that supports mpeg 2), so if Nero has any trouble with it, renaming it should work (I don't use Nero to encode or author, just to burn).
The main thing to take into consideration is whether or not your DVD burner supports DVD-RAM discs. If it doesn't, you're not gonna be able to get the .vro files onto your computer.
picture control on Panasonic dmr e55
By mammo1789 in forum DVD & Blu-ray RecordersReplies: 3Last Post: 20th Jan 2012, 17:41 -
.VRO files & windows media player
By jon22330 in forum Video ConversionReplies: 6Last Post: 28th Dec 2010, 14:06 -
vibration in Pana DMR-E55 when using DVD-RAMs
By johnsees in forum DVD & Blu-ray RecordersReplies: 22Last Post: 24th Feb 2010, 23:25 -
Pana E55 vibrates when recording DVD-RAMs
By johnsees in forum DVD & Blu-ray RecordersReplies: 0Last Post: 28th Sep 2009, 01:58
