hey,
is there any possibilty that i can convert a 320x240 video into 720x576 without quality loss????
Results 1 to 9 of 9
I really don't think so. IMO your best bet is to encode to 352x240. 320x240 isn't great resolution anyway so increasing it will more than likely just produce macroblocks.
Donadagohvi (Cherokee for "Until we meet again") -
For PAL, 352x288
And watch those framerate conversions.Want my help? Ask here! (not via PM!)
IMHO, no, no possible way.Originally Posted by vidhya_80in
You'd be relying on your encoding software to be "guessing" the contents of roughly 80% of the pixels per frame, and no encoding software I know of is gonna pull that off, while keeping the quality of the original. Converting something to DVD specs doesn't automagically make it DVD quality
If in doubt, Google it. -
That's a great word.Originally Posted by jimmalenko
I really never understood whether the quality is better at 720/586 than 320/240...
I have a 31" television and I can't see any big difference... -
Depends on the source, if you take a high quality source you'll see the difference immediately. It will appear softer with less detail. VHS is not that great a source so it won't be that noticeable.Originally Posted by malisamson
There some links to high quality DV-AVI here you can try it yourself if you want:
https://www.videohelp.com/forum/viewtopic.php?t=257651
That's a good one for the glossary. Aotumagically.......Originally Posted by lordsmurf
Converting DV 720x576 with AR 16:9 to AVC using libx264 and FFCoder
By klode in forum Video ConversionReplies: 3Last Post: 11th Dec 2011, 10:57 -
blu ray player says video larger than 720x576
By PSS2 in forum Authoring (Blu-ray)Replies: 4Last Post: 4th Jul 2010, 16:07 -
3GP with 320x240 not possible?
By ahollmann in forum ffmpegX general discussionReplies: 2Last Post: 22nd Aug 2009, 06:29 -
320x240 mp4
By OG24 in forum Newbie / General discussionsReplies: 15Last Post: 17th Jul 2008, 03:14 -
DVD TO DivX (PAL 720x576 16:9 Letterboxed)
By SamFisher in forum DVD RippingReplies: 16Last Post: 10th Jul 2007, 20:17
