I have been using ffmpegX (registered version) for about 6 months with no problems. Great program. Then suddenly it stopped creating VIDEO_TS folders and all the others files that get created at the same time. The only file I get is a single "____.divx.ff.mpv" file. All my settings in the program are the same as previous times, Author as DVD (VIDEO_TS) is checked in the Tools menu.
Tried 3 times with 3 different types of files (to see if it was the program or an individual file type), and I stilll just get one .mpv file. The only change I made to my system was to upgrade to Quicktime 7 (I'm on a Macintosh). I checked the Library/Application Support/ffmpegX (folder) and all the binaries are there.
Any suggestions or support would be great.
Thank you very much.
Results 1 to 13 of 13
Make sure the process was finished (the word "Finished" was displayed in the Progress window). If yes then email me the process output (obtained by clicking the blue "i" icon in the progress window) to major4@mac.com for further inspection.
I'm not 100% certain about this since I don't use the video_ts creation all that often, but I seem to remember that some part of the post processing will fail if there are spaces in the file names, or if the file names are too long or something.
Since you have your mpv, create your audio file with the "movie audio to..." preset and then rename them something like movie.mpv and movie.ac3 and try muxing and authoring them from the tools tab.
Alph
Originally Posted by major
Hello
I also have AUDIO_TS & VIDEO_TS problems
When the word "Finished" appears in ffmpegX program, It does not mean everything is finished.
Sometimes if I open the ____.mov Folder , I can see that the HD is still working , gettin' bigger and bigger. And only after a while the all thing stops.
Sometimes I can use this ____.mov Folder and everything is OK.
Sometimes Nothing in this file is good to use (Black and/or no sound)
25 % success but each time It was 7 or 10 Hours waiting before I know if the job is good or not
Chrts
I had a similar problem today (also registered user). I tried encoding an Mpeg1 file from Eyetv USB and I followed the directions in the "How to" for DVD: encoded using DVD mpeg2enc and saving to a folder on my desktop. Several minutes after the progress bar window said "Finished" I opened the folder and found only one file - suffix was .m2v. No TS Video and TS Audio files! QuickTime wouldn't open it, saying there was an error. VLC did play the file...but there was no audio. What did I do wrong?
cheers,
ncm
G4 MDD Dual 1.25 GHz/2 Gb RAM
OSX 10.3.9
G4 PowerBook al 1.33 GHz/768Mb RAM
OSX 10.4.1
Email me to major4@mac.com the contents of your process output (blue "i" icon in the progress window) for inspection.
Well, after last night's failure I just quit ffmpegX and trashed the useless file, so I can't find the log. But tried again with a different file today and this time it worked. On the previous one I had changed the destination name and folder. This time I left it at the default. Dunno if that was the issue.
cheers,
ncm
Input #0, avi, from '/ARRIVE G4/FILMS (On:Off)/ENREGISTRES CORBEILLABLES/Les barbouzes.avi':
Wed Jul 13 10:33:11 CEST 2005
Duration: 01:43:32.0, start: 0.000000, bitrate: 941 kb/s
Stream #0.0: Video: mpeg4, 640x384, 25.00 fps
Stream #0.1: Audio: mp3, 48000 Hz, stereo, 192 kb/s
Output #0, rawvideo, to '/ARRIVE G4/FILMS (On:Off)/ENREGISTRES CORBEILLABLES/Les barbouzes.avi.ff.mpv':
Stream #0.0: Video: mpeg2video (hq), 720x576, 25.00 fps, q=2-20, 4000 kb/s
Stream mapping:
Stream #0.0 -> #0.0
video:3033186kB audio:0kB global headers:0kB muxing overhead 0.000000%
bench: utime=4960.156s
Input #0, wav, from '/ARRIVE G4/FILMS (On:Off)/ENREGISTRES CORBEILLABLES/Les barbouzes.avi.ff.wav':
Duration: 00:42:44.6, start: 0.000000, bitrate: 1536 kb/s
Stream #0.0: Audio: pcm_s16le, 48000 Hz, stereo, 1536 kb/s
Output #0, ac3, to '/ARRIVE G4/FILMS (On:Off)/ENREGISTRES CORBEILLABLES/Les barbouzes.avi.ff.ac3':
Stream #0.0: Audio: ac3, 48000 Hz, 5:1, 448 kb/s
Stream mapping:
Stream #0.0 -> #0.0
video:0kB audio:140256kB global headers:0kB muxing overhead 0.000000%
STAT: Picking VTS 01
STAT: Processing /ARRIVE G4/FILMS (On:Off)/ENREGISTRES CORBEILLABLES/Les barbouzes.avi.ff.mpg...
STAT: VOBU 16 at 3MB, 1 PGCS
STAT: VOBU 32 at 8MB, 1 PGCS [..]
STAT: fixing VOBU at 2726MB (11665/13700, 85%)
STAT: fixed 13700 VOBUS
INFO: Scanning /ARRIVE G4/FILMS (On:Off)/ENREGISTRES CORBEILLABLES/Les barbouzes.avi.ff.mpg.DVD/VIDEO_TS/VTS_01_0.IFO
Encoding completed on Wed Jul 13 13:43:31 CEST 2005
FILM OK but no sound
Originally Posted by CHR
No MOV thumbnails in XP folders?
By terrypin in forum Newbie / General discussionsReplies: 13Last Post: 30th May 2011, 13:08 -
ts_video
By GarryFama in forum ffmpegX general discussionReplies: 2Last Post: 26th Jul 2009, 10:47 -
FireWire Stopped
By Mark Smith in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 2Last Post: 5th Feb 2009, 12:17 -
Folders keep shutting down?
By aelfheah in forum Newbie / General discussionsReplies: 12Last Post: 26th Feb 2008, 14:07 -
Can't burn TS_Video files
By OzarkBaby in forum Newbie / General discussionsReplies: 5Last Post: 5th Jan 2008, 19:23
