Which editing software can I use to edit my dvds. What freeware program would you recommend? I will be trying this out for the first time.
IMHO the best freeware editor is virtualdubmod (and any of virtualdub's other variants). This is only good for simple cuts though - no transitions or anything like that unless you're adept at AVISynth scripts.
I've never used it for editing, but Windows Movie Maker comes with WinXP, is free and can do transitions, and also offers the choice of timelines or storyboards.If in doubt, Google it. -
Thanks for your prompt reply. I do have windows movie maker, I didn't know I could use it. I will also try virtualdubmod.
Cheers
If you are working with MPEG files, Cuttermaran is one, or if you have TMPGEnc encoder, it can do simple edits. For more complex MPEG editing, MPEG Video Wizard is good but not free. Not much freeware for decent MPEG editing. In 'Tools' to the left, there are more choices.
DVD Editing And Authoring Software
By garystan in forum Authoring (DVD)Replies: 3Last Post: 14th Aug 2011, 06:11 -
Video Editing Software: mkv, h264 & DTS Editing?
By techdls in forum EditingReplies: 8Last Post: 28th May 2011, 02:29 -
DVD editing software
By Mike_EH in forum Newbie / General discussionsReplies: 13Last Post: 3rd Sep 2010, 22:43 -
By wotadan in forum EditingReplies: 3Last Post: 18th Mar 2010, 09:17 -
DVD Editing Software
By Compubooth in forum EditingReplies: 2Last Post: 29th Dec 2007, 19:20
