    Jul 2004
    Manchester, UK
    Hello,
    I recently used a program to back up a bought DVD on my laptop for cataloging and viewing on-the-go. The original disc which I purchased has since become damaged. As I have already bought it, I would now like to re-render the DivX version into Mpeg to play on a DVD. The problem is, the files are split into CD1 and CD2. Can anyone help with pointers on how to get DivXToDVD to join the two files?
    Peter. 8)
    Dell Dimension 8100, 1.7 P4, XP Pro, 512 rd RAM, 40Gb HDD, 40Gb additional HDD, 160Gb ext HDD, Pioneer DVR 106 DVD RW, Vegas 4, JVC GR DVL 367.
    Jul 2004
    Manchester, UK
    Cheers Baldrick,
    I have done this, but am I bit worried that the order in which the two files appear in the 'source' window in DivXToDVD is back to front. CD2 is first, with CD1 second. Does this matter or is as simple as putting CD1 first in order?
  3. Член BJ_M's Avatar
    Jul 2002
    Canada
    you backed up a dvd on your laptop to cd1 and cd2 ?
    Jul 2004
    Manchester, UK
    Thanks for all your help, sorted it now.
