Ok here's the deal, I am not a tech Wizard , I know very little about computers. I just installed a brand new DVD burner , It worked for a few days now it won't write ... this is the second DVD burner i have installed. I use cloneDVD and DVD X copy Gold. On both types of software it prepares the files for writing but it freezes when it comes to burning...if it does write the quality of the movie is so horrid it's not funny. Please be gentle I am not a comp wiz. Thank You
Hi, could you describe your problem in your subject field next time.
Please read the rules and AUP before posting if you have
not already done so. They can be viewed by clicking [HERE]
Thanks,
Mod Offline
Post what media & burner you've used.
Check to make sure that you're in DMA mode.
Download & try freeware like DVD Decrypter & DVD Shrink.If God had intended us not to masturbate he would've made our arms shorter.
George Carlin -
Have you put the jumper on the correct slot on the back,Master,Slave?
Have you updated its firmware? -
yes i have. on both accounts. this is the second burner to do this. im thinking something in the computer itself is ruining these drives. i tried another movie last night. it burned fine but when it was played back it was so choppy and unwatchable i just tossed it away.
How many working discs have you made?
George Carlin -
sounds like a software conflict.....dvd x copy can cause conflicts with other burning software.....toshiba doesn't do well in writing dvd media.....if your problem continues i'd return the toshiba drive and get another brand...and uninstall that dvd x copy....as already suggested just use freeware DECRYPTER & DVD SHRINK.....
i have made around 20 id say. my other comp had both clone and dvdx and never had a probelm with that one. and the HP burner is doing the exact same thing as the toshiba so most likely it is software but not thinking dvd x is the problem. but i could be wrong i will take it out and try it.
Two simple questions, plz help!
By UnD3R0aTh in forum DVD RippingReplies: 40Last Post: 4th Mar 2010, 11:47 -
help with megui error plz
By runLoganrun in forum Blu-ray RippingReplies: 1Last Post: 17th Feb 2010, 22:43 -
You want newbie? This is newbie. Watch VHS movies.
By Mighty Melvin in forum Newbie / General discussionsReplies: 14Last Post: 12th Oct 2009, 09:43 -
plz help
By sajjad223 in forum Video Streaming DownloadingReplies: 1Last Post: 4th May 2008, 11:12 -
I need a guide to convert avi to dvd plz (newbie topic) help
By Death009 in forum Newbie / General discussionsReplies: 4Last Post: 24th Oct 2007, 08:03
