When I use nero to do this it reencodes everything with lesser quality than the original DIVx avi file. I would like to get the AVI file onto a DVD playable format with the lowest quality loss from the original file.
Don't use Nero for anything but burning. It tends to want to re-encode whether it needs it or not. It is a poor encoder.
If you have a DIVX file that you would like to play on a settop DVD player you need to encode it to MPEG-2 or MPEG-1. Nero sucks at that. Quick and easy is VSO DivxToDVD.
Or you can use TMPGEnc encoder to convert to VCD or DVD format. -
http://members.dodo.net.au/TMPGEnc1CD.htm for a one disc XVCD or http://members.dodo.net.au/~jimmalenko/AVI2DVD.htm for a one disc DVD
If in doubt, Google it.
How can I Burn DVD using avi file and .srt file as subtitle
By Gayanx in forum Authoring (DVD)Replies: 7Last Post: 15th Jul 2012, 01:56 -
DivX File, How Do I burn To DVD???
By jam90 in forum Video ConversionReplies: 3Last Post: 27th Jan 2008, 15:49 -
Burn .avi file to VCD while still retaining subtitles
By Holymoly in forum Video ConversionReplies: 1Last Post: 12th Dec 2007, 22:30 -
Help with re-encoding avi files (XviD/DivX)
By noskid21 in forum Newbie / General discussionsReplies: 2Last Post: 18th Aug 2007, 15:24 -
How do I burn Divx file on to a CD.
By Leak in forum Newbie / General discussionsReplies: 3Last Post: 7th Jul 2007, 13:56
