Hi,
I put in a disk into DVD Shrink, and after compression and such, it is still too big. Is there a way to change this, or another program that will eliminate this.
Thoughts and ideas are appreciated.
Results 1 to 12 of 12
Run the Shrink file through Shrink again or if you don't want to lose quality, split it to two discs. Generally if you have to Shrink it below 60% you will lose a fair amount of quality.
You can also dump everything on the disc except the main movie and if you really want the extras, burn them on a separate disc. With a few movies, even the main movie is very long, up to three hours. It comes down to what you want and how much quality you want it to be. -
Originally Posted by guru
- Run through DVDShrink again
- Try a different transcoding software (DVD2One, CloneDVD, DVDXCopy)
- Remove some unwanted extras using VOBBlanker or TitlesetBlanker before transcoding
- Set some unwanted extras to still pictures in DVDShrink
- Buy a DL burner and do a 1:1 copy
- Demux the VOBs, transcode using Rejig and the rebuild the disc
- Re-encode using DVD-RB
That's all I can think of for now, but I'm sure I've probably missed some obvious alternatives ...If in doubt, Google it. -
Originally Posted by DragonsfMy oppinions may change, but not the fact that I am right!
www.rockassoftware.pt.vu
DAudioK => https://forum.videohelp.com/viewtopic.php?t=306886
DVD Rebuilder
http://dvd-rb.dvd2go.org
http://www.jdobbs.com -
Use DVD-RB for this situation.
Originally Posted by jimmalenko
"Buy a second copy of the DVD"
am I right
DVD Rebuilder
I have had this problem and solved by reducing the target size of the disk to about 4.2gig and reshrunk the original files. You can set the output disk size to what you want. Nyah Levi
Will DVD Shrink shrink an ISO image?
By brassplyer in forum DVD RippingReplies: 26Last Post: 19th Sep 2013, 22:03 -
Backing up DVD/Blu-ray to disk, watching movies directly from disk to TV.
By mb312 in forum Newbie / General discussionsReplies: 0Last Post: 11th Feb 2010, 15:35 -
Big big troubles with firewirre PCI card.
By SE14man in forum Newbie / General discussionsReplies: 1Last Post: 29th Feb 2008, 23:51 -
What to do when DVD shrink does not shrink enough
By Firewire60 in forum Video ConversionReplies: 4Last Post: 23rd Sep 2007, 23:07 -
how to shrink a movie with DVD Shrink?
By php111 in forum Newbie / General discussionsReplies: 2Last Post: 22nd Aug 2007, 17:59
