  1. Hello while trying to add subtitles to a DVD I get the following error:
    Process aborted due to above error
    Error code #5
    There was an error in multiplexing the titles. One of the m2v files has 'end sequence codes' in it that must be removed in order for it to multiplex correctly. This could be caused by an mpeg joining program or something similar. Use restream to remove these 'end sequence codes'. (http://shh.sysh.de/restream.html) Please review the log for more detailed information.
    Is there any way to get past this?
  2. Free Flying Soul liquid217's Avatar
    Feb 2002
    I am assuming you used DVDAuthorGUI. And yes, follow the above steps to remove the end sequence codes from the m2v.
  3. I tried that but it didn't work
    Is there a link to a FAQ to use the program suggested?
    Please forgive me but I'm new to this video authoring and such.
  4. Free Flying Soul liquid217's Avatar
    Feb 2002
    if you can, email me the log, and I will try to help you out.
    liquid_217@hotmail.com
