  1. I'm trying to backup a DVD that has LPCM audio which takes up a whopping 1.5Gb on the DVD. When I attempt to backup the DVD using DVDShrink the compression is set to 39.9 - way too low for me.
    Is there anyway to convert this LPCM audio to AC3 so I could save enough space to backup the DVD with a decent compression level ?
    Buddha says that, while he may show you the way, only you can truly save yourself, proving once and for all that he's a lazy, fat bastard.
  2. Thanks Balders, you're a god send.
  3. You may want to look into BeLight as it's a better and user friendly GUI for BeSweet.
  4. I would use DVDDecrypter->IFO Mode->Stream Processing->Demux(go to Settings->IFO Mode and set File Splitting to none).
    Then use ffmpeggui to convert LPCM to AC3.
    Then use IFOEdit,DVDLab,etc to author.
  5. Originally Posted by DoubleShadowIce
    This I will be doing, I can't bloody stand Besweet.
    @Moviegeek
    Cheers - I'll be looking into this.
