Get an error when trying to author a dvdr from a DVD ram disc (Panasonic DMR E50 recorder and Pioneer D107 burner) The original program was from SKY +, then burned to RAM disk, want to add chapters etc on the pc first before burn to dvd-r.
'The program is a mix of different video formats. Compression, resolution and aspect ratio must be the same within the program'
I imagine this is a setting on the dvd recorder causing this? What should I look out for.
Cheers
Stevie
Glasgow -
Functions - Setup - Video - Hybrid VBR Resolution.
Change from Automatic to Fixed. -
Thanks man, I take it this only applies to RAM disks? It hasnt happened before with normal dvd-r's
Stevie
Glasgow
DVD FLICK, Start-up Error Msg-Unable to created txt file. Last DLL error: 5
By jacknscoob in forum Authoring (DVD)Replies: 5Last Post: 4th Mar 2012, 09:58 -
Tmpgenc dvd author 3 will not author my m2v files????
By biged670 in forum Authoring (DVD)Replies: 1Last Post: 28th Sep 2009, 12:10 -
TMPGEnc DVD Author Error - Video Bitrate too high
By powerkoala in forum Authoring (DVD)Replies: 9Last Post: 22nd Nov 2008, 12:16 -
TMPGenc DVD Author 3 issues "No stream available" Error Code 0x80
By newsletters in forum Video ConversionReplies: 0Last Post: 8th Oct 2007, 18:20 -
TMPGenc just closes - no error msg - no rhyme or reason! Help please.
By brightsun23 in forum Video ConversionReplies: 3Last Post: 15th Jun 2007, 12:42
