I have VCDs from Europe and Far east which carry different language on left and right audio channel. When I play them with standard Windows media player, two languages come out of both channels. I have to use left and right balance to shut down one channel. This does not sound good when sound is only coming out of one speaker. I installed InterVideo WinDVD , but there is no L/R audio selection.
Does anyone know which software player has the feature to allow me to play only the channel I like.
I'm not currently at my computer but I recently installed a copy of PowerDVD 5 from CyberLink that came with a burner. I remember seeing a Karaoke menu item when I right clicked the 'display' window. I'll check what options, if any, there are when I get home shortly.
Well, I checked it out and there is a Karaoke menu option with a sub menu showing:
Vocal None
Vocal 1
Vocal 2
Vocal Both
Unfortunately they are all grayed out during DVD playback. Maybe it's active in the deluxe version or something?
Anyway, I couldn't play CD+Gs but it is more than likely my drive. Also, when playing a Karaoke VCD the options above didn't appear. -
Seems kinda odd that there are different audio tracks on the left and right channels. Are you sure it isn't a SVCD with 2 audio tracks?
Google is your Friend -
Typically, Karaoke VCDs are mixed with 2 channels: one with the vocals and one with the music. This is to allow 'hardware' karaoke players to be switched or cycled between: Left Channel only, Right Channel only, Dual Mono (to allow the single channel of music to play in both the left and right speakers for true karaoke without demonstration vocals) and regular Stereo - demonstration vocals and music. I personally haven't seen any karaoke Super VCDs (doesn't mean they don't exist though). PowerDVD justs labels the 'modes' differently using the word 'vocal' alot.
Button command(s) to select audio and subtitles simultaneously
By dexter30 in forum Authoring (DVD)Replies: 1Last Post: 26th Mar 2012, 15:42 -
Possible to select audio and automatically turn off subtitles?
By kpic in forum Authoring (DVD)Replies: 5Last Post: 21st Feb 2011, 06:59 -
How to select audio channel when converting MKV files ?
By vcd_user in forum Video ConversionReplies: 1Last Post: 23rd Aug 2010, 16:48 -
Is there a dvd player that you can select ycbcr601 other then the Xbox 360
By Evil Monkey in forum DVD & Blu-ray PlayersReplies: 1Last Post: 1st Jun 2009, 08:44 -
Camstudio -> Unable to select audio encoding in Mp3 @44.1 kHz
By ontherocks in forum Newbie / General discussionsReplies: 3Last Post: 20th Jul 2008, 16:44
