I don't know if this is the proper place to post the question but here it is anyway...
I downloaded something that came in multiple tda files. I'm not at all familiar with this type of file and can't really find much to help me out.
I'm wondering how I should burn these files.
Sounds like you are trying to use Bit torrent. Do a search on google for Bit Torrent. You will find alot of Info.
I saw tda & thought TMPGEnc DVD Author
Usually when you get multiple files from any download they are winrar files..
Have you tried opening the main one and extracting what is in it ?
Usually when you do it will automaticaly extract the files from the other's and put them all together.
& watch those dirty words
TDA errors
By siluet in forum Newbie / General discussionsReplies: 4Last Post: 17th Sep 2009, 07:08 -
TDA 4 Demo
By pepegot1 in forum Authoring (DVD)Replies: 0Last Post: 15th Feb 2009, 11:21 -
TDA 1.6 menu help
By colt4523 in forum Authoring (DVD)Replies: 0Last Post: 3rd Nov 2007, 18:46 -
TDA 3 Quirk
By pepegot1 in forum Authoring (DVD)Replies: 2Last Post: 8th Oct 2007, 10:37 -
reauthoring TDA video in TDA throws audio off
By spiritgumm in forum Authoring (DVD)Replies: 8Last Post: 14th Sep 2007, 18:04
