I just updated to 6.6.1.4 package from my bundle software.
The problem is, besides all the junk, is that the plain ole' Burning Rom is not there anymore.All I can find is that lame express that from the looks of it, wont burn DVD properly.
Anyone know if this is the case with the new update?
When going to burn a DVD, there used to be the AUDIO TS and VIDEO TS folders already there, then you drop your DVD files into VIDEO TS folder it made for you.
This is not the case anymore.No folders, cant make them, all it does it add the files.
I have not found a way to enable any different 'wizard' or anything.
Can anyone elaborate on this issue? Is it time to move on to another software program since it seems NERO is always messing with things.
Originally Posted by NotSoEasy
There might be a button, I don't know. But it might be located where the circle is... -
To disable NeroExpress
If you can get into Nero ROM, uncheck Use Nero Express.[/b] -
And yes, express WILL burn them correctly... what i have used 99% of he time for the last few years....
Man, you must have been using an old version of nero because i have not seen the folders being showed in a LOOOOOOONG time........
Bundled software eliminates certain features based on what number you register it with. I personally have an express # that came with my writer and an ultra edition # which I bought prior. I updated, entered express # and only had a few progs. Turned around and just entered ultra edition # and all progs suddenly appeared like magic.
http://members.dodo.net.au/~jimmalenko/NeroExpress.htm - perfect results for me, every time.
If in doubt, Google it. -
Just an update for you all.
The version I had was a bundle with my writer.It was OEM SUITE 3 version 6.3.1.11 with:
dos driver
nero express 6
incd 4
nerovision express 2
nero backitup
mpeg-2 svcd/dvd plugin
dvd-rewritable drive
manual
acrobat reader
I just went back to my old version so I dont have to mess around with it.
Thanks for the replies and help.
CD-ROM vs. DVD-ROM
By Judson in forum MacReplies: 10Last Post: 6th Apr 2012, 08:33 -
Problem burning data DVD using Nero 6 burning rom
By thebluekey_17 in forum Newbie / General discussionsReplies: 3Last Post: 19th Feb 2009, 13:14 -
Nero Recode 3.1.2.0 -- "Nero Digital Standard" vs. "Nero Dig
By GrayStrickland in forum DVD RippingReplies: 1Last Post: 15th Dec 2008, 19:23 -
Nero Burning Rom 8.3.6.0
By jebinio in forum ComputerReplies: 1Last Post: 14th Sep 2008, 10:29 -
how to create folders in nero burning rom or express?
By jyeh74 in forum Newbie / General discussionsReplies: 3Last Post: 22nd Dec 2007, 23:54
