I've been trying to convert this video file I have, which plays fine, and can even be opened in many programs, i tried all sorts of video conversion programs, and they all have the same problem.
about 1:30 into the file, the conversion stops, im guessing the file is damaged, i tried fixing the header, and used all media fixer, and still won't convert the whole file. it plays though.
gspot says all the codecs are installed
Thanks in advance
What are your trying to convert it into? What programs are you using?
"Art is making something out of nothing and selling it." - Frank Zappa -
i tried converting it to .wmv and .avi with no luck, they both stop converting at the same spot. i tried various converting programs with no luck,just the same results
You might want to do a Google search for 'Mpeg1 payload'. There may be some solutions, but It's apparently a propitiatory format. No easy way to do what you want. Used on some sites that don't really want you to copy their 'material' for legal and other reasons.
EDIT: And thanks for the Gspot screen, that makes it much easier.
Converting MOV to MPEG-2 File
By cyberboy in forum Video ConversionReplies: 5Last Post: 16th May 2009, 18:39 -
Converting MPEG into a smaller file size?
By ione in forum Video ConversionReplies: 3Last Post: 9th Sep 2008, 23:36 -
Converting MOD file to AVI or MPEG!!!
By OnelnAMiII25 in forum Video ConversionReplies: 10Last Post: 5th Mar 2008, 16:48 -
Converting EyeTV MPEG file
By lkearl in forum ffmpegX general discussionReplies: 8Last Post: 7th Feb 2008, 11:58 -
Converting audio from a mpeg file to a mp3 file?
By hrace in forum Newbie / General discussionsReplies: 2Last Post: 6th Dec 2007, 17:15
[/img]
