You might also be dyslexic.
Results 31 to 46 of 46
I don't have a bad attitude...
Life has a bad attitude! -
Originally Posted by Fandim
Might as well be contrarian here.
If it's just a few percent, I'll shrink it without DA or AEC. If significant compression is required, run it through DVDRebuilder. Doesn't take all that much longer than DVDShrink with DA and AEC enabled. So re the original question, no I don't see much point to it.
Pull! Bang! Darn! -
Originally Posted by guns1inger
But it's difficult for me to see more than a slight improvement using DA and AEC. Particularly if the ratio is at 90% or above. That's on a 32" HDTV CRT. DVDRB results in a noticeable improvement over DVDShrink (with or without DA and AEC) when the compression required is greater than that. So my attitude is, if it's worth extra time, it's worth re-encoding. To each his own. JMO.Pull! Bang! Darn! -
gunslinger wrote:
Actually, unless the disk is 4:3 letterboxed, most of the screen is video. If your disk is "widescreen enhanced", "16:9", "Anamorphic" etc, then your player is adding the black bars by compressing the image. There is as much data on a 16:9 1.78:1 movie as there is on a 4:3 fullscreen disk. Even a 16:9 disk with a 2.35:1 AR movie fills better than 50% of the screen area with movie. -
Even with both turned on, Shrink takes about 25% of the time of rebuilder for the same file. If Shrink is taking that long there is definately something wrong with your setup.My oppinions may change, but not the fact that I am right!
www.rockassoftware.pt.vu
DAudioK => https://forum.videohelp.com/viewtopic.php?t=306886
DVD Rebuilder
http://dvd-rb.dvd2go.org
http://www.jdobbs.com -
I use Deep Analysis and AEC Sharp if compression required is more than 97%. I'm not seeing any more artifacts than the originals on my high end equipment.
I used to use CCE a few years ago, but recent versions of Shrink do great even at 70% comopression, and rarely does something need compressed more, so I dont waste my time firing up CCE anymore. In recent comparisons, I determined Shrink was better.
Tip - get rid of the crap, menus, extras, etc. Enjoy. -
Tip - get rid of the crap, menus, extras, etc. Enjoy.My oppinions may change, but not the fact that I am right!
DVD Rebuilder
Originally Posted by Rockas
Originally Posted by jimmalenko
That's a good one!
I think that was the definition of impossible.
PM me to hear my all-time favorite - I initially posted it here, but it is of a sexual nature and may offend, so I've removed it.If in doubt, Google it. -
I've got to say, it used to take 3+hrs on my old 1.4ghz amd with dvd shrink!
with my new amd 2.4ghz with all the whistles (sort of) pc 3200ram yadda yadda it takes an hour or maybe 1.5 depending on the movie. We're talking saving private ryan or s0pranos season 5 so its definitely a heavy load not like 10% compression.
maybe you should look at your hardware? celeron may not be good at crunching those type of #s. -
From my experience, using the deep analysis is definitelly worth the time. I had some discs that I did using the default settings, and in some scenes, when the shots changed back and forth, there would be bad macroblocking for a couple of frames (definitelly noticeable). When I redid them with the deep analysis and the default sharpness setting, the problem went away and the video looked better overall.
It takes me about 90 minutes on a 2.4GHz computer (my secondary system). For me, I'm willing to wait the extra time for the quality boost.
Recommend fast & small (few system resources) DVD utilities quick analysis?
By MISS CHIEVOUS in forum Newbie / General discussionsReplies: 0Last Post: 4th Jul 2010, 15:37 -
Looking for a tool which has DVDShrinks compression ability
By branch in forum Video ConversionReplies: 6Last Post: 5th Dec 2009, 05:21 -
Suddenly my DVDshrinks aren't reading on players
By john mcmillan in forum DVD RippingReplies: 15Last Post: 23rd Oct 2008, 13:47 -
How to Deinterlace using Motion Compensation?
By Undead Sega in forum Video ConversionReplies: 18Last Post: 15th Oct 2007, 08:58 -
Desperately Looking for a DVD Player with Overscan Compensation Feature
By Cottontree in forum DVD & Blu-ray PlayersReplies: 2Last Post: 5th May 2007, 16:53
