  1. i have a whole bunch of different .vob files that all have 2 audio track, when i use TMPgenc author and compile the .vob file into 1 disc the result are movies that's missing the 2nd audio track, is there anyways to fix this problem?
  2. I do not think TMPGEnc DVD Author handles multiple audio tracks or subtitles to be honest.
  3. VH Veteran jimmalenko's Avatar
    Aug 2003
    Down under
    aguillon is right - no multi audio tracks or subtitles - try demuxing in something like VOBEdit then use something like dvd-lab, or any other authoring software that does support these features.
    If in doubt, Google it.
  4. dvd lab was too hard to work with for me, is there any other software/ ways to complete this task?
  5. VH Veteran jimmalenko's Avatar
    Aug 2003
    Down under
    sure. Go to Tools (to your left). CLick on the DVD Authoring link. There's heaps of different softwares listed there.
