I did a new search excercice on handling of DVR-MS files and didn't find anything newer than what I use. So please read what I do and if anyone has anything better to offer, PLEASE do.![]()
The best solution I've found is to convert the dvr-ms recording to MPEG using DVR-Ripper and then import the MPG file to VirtualDUB-MOD for trimming, save to AVI using DivX CQ=2 and then re-encode to MPG using CCE.
The results I get are excellent for broadcast material with the only glitch being that DVR-Ripper introduces a 600mSec delay to the audio which I have to fix with VirtualDUB during trimming.
Another issue is that being unable to trust actual broadcast times, I have to record quite a few hours during the night, which at highest quality produces 16Gb files. DVR-Ripper takes 90 minutes or so to convert, VirtualDUB takes another 10 minutes to import the MPEG file and then another hour to save to AVI.
I would be more than happy if I was able to directly import the dvr-ms file to VirtualDUB. No luck there since the author is afraid of violating MS patents.
Considered Tmpgenc Express, which in the latest update can import DVR-MS files, however the editing capabilities are quite limited and conversion to DivX AVI is quite slow.
Is there any way I can avoid the extra DVR-MS --> MPG conversion step? It's not only a matter of time wasted, I also need to save the original recording until the MPG is done, I cannot delete both of them until I have trimmed and proof-viewed the resulting AVI and the whole thing makes the 160G of the single disk HTPC very full very fast. Copying stuff on the main machine over the Ethernet is not very productive also.
I am now considering doing the initial conversion out on a USB-2 disk and transfer the disk to the main machine for further processing - something that may prove to be a major improvement unless a kind soul has a better feat to offer.
Waiting in agony
yours truly,
Just another WinXP MCE 2005 victim![]()
The more I learn, the more I come to realize how little it is I know.
bump!
The more I learn, the more I come to realize how little it is I know. -
Take a look at this link. I to am learning to work with dvr-ms files.
http://msdn.microsoft.com/smartclient/default.aspx?pull=/library/en-us/dnxpmce/html/dvr-ms.asp
mwh99
Decrypting dvr-ms or mpeg-2 files?
By columbia93 in forum Video ConversionReplies: 2Last Post: 30th Oct 2011, 23:56 -
WTV/DVR-MS files into usable MPEG format?
By CursedLemon in forum Newbie / General discussionsReplies: 6Last Post: 24th Jul 2010, 09:21 -
Final Cut Pro not playing .avi files captured with CamStudio
By imagine3 in forum MacReplies: 1Last Post: 29th Sep 2009, 11:57 -
*.avi files captured from miniDV tapes with WinDV no longer plays
By gho in forum Software PlayingReplies: 5Last Post: 1st Jul 2008, 21:51 -
Convert dvr-ms files to mpeg?
By Datahead in forum Newbie / General discussionsReplies: 4Last Post: 22nd May 2007, 20:12
