I have a file I am having prolems converting a file
GSpot reports the file as this:
File Type: 3GPP Media (.3GP) [MP4 compat.]
Mime Type: video/mp4
audio is blank
I used ImTOO 3GP Video Converter to convert to divx.
Summary:
Duration: 00:54:32
Bit Rate: 569kbps
Video:
Format: mpeg4
Frame rate: 25.00fps
Audio:
Format: mpeg4aac
Bit rate: 0kbps
Sample rate: 16000Hz
Channels: stereo
Gspot now reports it as
Codec : 0x0055(MP3, ISO) MPEG-2 Layer 3
16000Hz 64 kb/s total (2 chnls)
Is there a way just change the Audio bit rate and/or Sample rate as the video is fine its that the sound is being played slow. Without encoding the whole thing again.
virtualdub
video->direct stream copy
audio->full processing
audio->conversion
audio->compress mp3
file save avi.
if it wont work try convert the audio from the 3gp to wav with goldwave and then use it virtualdub, audio->wav audio.
3GP
By begeta50 in forum ffmpegX general discussionReplies: 3Last Post: 16th Aug 2009, 11:15 -
FFMPEG 3gp conversion
By diskontrol in forum Video ConversionReplies: 1Last Post: 19th Dec 2007, 03:50 -
3gp conversion problem
By nddcndndd in forum Portable VideoReplies: 5Last Post: 20th Oct 2007, 13:15 -
FFMPEG 3gp
By dizzy123 in forum EditingReplies: 3Last Post: 6th Sep 2007, 03:24 -
ffmpegx.... 3GP conversion= bad quality
By PIZZ in forum ffmpegX general discussionReplies: 1Last Post: 7th May 2007, 11:04
