Hello,
Could someone help me out ?
I have a mpeg coding at 23 fps i want to convert to 29 pfs nay tool or programe can do it ? plz help ?
H
Results 1 to 11 of 11
dgpulldown should do the job.
You need to demultiplex, run it through dgpulldown and then remultiplex. I don't think there is any program that can add pulldown flags to a program stream, only elementary streams.
Indeed. Thats what i meant. the dgpulldown home page describes the steps required:
A typical workflow is as follows (assumes you are starting with PAL source material):
Demux the video and audio streams.
If the video is interlaced, deinterlace it to make it progressive. If it is already progressive, skip this step.
Resize the video to 720x480.
Encode the video to MPEG2 at 25fps progressive.
Run DGPulldown on the video MPEG2 stream to flag it up to 29.97fps (using the 25fps --> 29.97fps conversion).
Mux the audio and video into a program stream, or author a DVD using the audio and video streams.SVCD2DVD v2.5, AVI/MPEG/HDTV/AviSynth/h264->DVD, PAL->NTSC conversion.
Hello,
do you know which programe is good for mux and demux video stream ?
H -
Hello,
I used dgpulldown. it doesn't give a goood sound. I am not sur that my video file is broken or not if yes does any tool can prepaire ? if not does another tool can do the jobs like dgpulldown ?
H -
1. demultiplex the mpg to mpv/m2v and mpa/mp2 or ac3
2. dgpulldown the mpv/m2v
3. add the mpv/m2v in tmpgenc dvd author and add the audio file -
Originally Posted by Baldrick
I did exactly all that. Even used TMPGEnc DVD Author for athoring. The result was out of sync sound. Any solutions?
is it possible to ivtc a 29fps ntsc source to 25fps xvid with gnot?
By iamtehsux in forum Newbie / General discussionsReplies: 65Last Post: 28th Dec 2010, 09:22 -
mixing 1280 x 720 29,97 fps and 1440 x 1080 25 fps in final cut
By perik in forum EditingReplies: 6Last Post: 17th Nov 2010, 23:42 -
Changing AVI from 29fps to 25fps
By Ric76 in forum Video ConversionReplies: 11Last Post: 22nd Jul 2009, 15:12 -
How to convert a video of 120 Fps to... well 23.9fps or 25 fps or 30 fps
By Chuba753 in forum Newbie / General discussionsReplies: 7Last Post: 6th Jun 2008, 20:17 -
Variable FPS MPEG-1 File
By Logis in forum Newbie / General discussionsReplies: 9Last Post: 5th May 2007, 15:04
