  1. i am using svcd2dvd version 2
    i converted a divx to dvd .. all converted fine .. when i play in a cheap dvd its fine .. but when i play in my pioneer dvd recorder and pioneer dvd standalone .. the picture breaks up goes outta sync and is un-watchable by any means ..
    is there a fix for this ??
    kind regards in advance
    xxvampyxx
  2. Member ChrissyBoy's Avatar
    Feb 2003
    Yorkshire!
    What build are you using?
    Are you converting from PAL to NTSC?
    Are your sources NTSC-Film
    Do you use pulldown?
    Can i see your log?
