I did a search and read a lot but didn't really see my problem discused, if I missed it I appolgize.
I have been using Sonic MyDVD to burn DVDs of some programs I've recorded. They are in "mpg" format, I guess mpg2. They are usually about 3GB in size. Normally when I go to load them in Sonic MyDVD it gives the size and it pretty much maches the recorded size. I use the "Fit-to-DVD" Quality setting and have never had a problem and get good recordings. Today something happened and I can't figure it out. When I go to load a video that is about 3GB, Sonic MyVD says it is 4.7 (or about) and won't record it. It says to reduce project size and try again. I haven't done anything that I know of.
Any help please?
If the source isn't dvd compliant it will reconvert and may make it bigger and mydvd may sometimes also reconvert a compliant source. Like reconvert the audio to wav/pcm audio and it will make it bigger. Try use something else like tmpgenc dvd author.
Font size will not change size
By pgwillin in forum ffmpegX general discussionReplies: 9Last Post: 8th Jan 2011, 14:04 -
Change the file size ?
By sat-jokar in forum Newbie / General discussionsReplies: 1Last Post: 27th Feb 2009, 18:32 -
Why cant i change audio output in MyDVD 10
By LiBiDoXP in forum Newbie / General discussionsReplies: 0Last Post: 14th Jul 2008, 01:16 -
How to change picture size
By hilario in forum Video ConversionReplies: 18Last Post: 24th Mar 2008, 08:04 -
large file size when importing small video clips into Sonic MyDVD
By artistream in forum Newbie / General discussionsReplies: 2Last Post: 1st Nov 2007, 19:48
