Hey. Someone help here plz.
I've already reinstalled all codecs but didn't worked.
Only movies recorded in MPEG2 works here.
If nothing work i'll have to format
The colors are all mixed. Like negative.
Unless I'm mistaken there is a known bug in those drivers that pertains to video. It has something to do with video overlay in the advanced settings. Let me see If I can find one of the other posts.
Google is your Friend -
Try this: Go to color correction in the geforce control panel- select overlay from where it says desktop.
Now at the bottom select advanced. Then click apply it will fix the gamma bug.Google is your Friend
TMPGENC Xpress and Video Mastering Works both crash at 99% of .mkv to mpeg2
By i am x in forum Video ConversionReplies: 3Last Post: 15th Jul 2014, 09:40 -
Re problems editing in tmpgenc authoring works 4 using multiple video files
By ukcalibrauk8 in forum Authoring (DVD)Replies: 4Last Post: 2nd Jul 2011, 03:25 -
TMPGEnc Authoring Works 4 problems...
By gonzalo76 in forum Authoring (DVD)Replies: 7Last Post: 12th Oct 2010, 02:59 -
File output issue from TMPEnc Author Works, VOBs -> single MPEG2
By aln688 in forum Video ConversionReplies: 4Last Post: 10th Apr 2010, 21:17 -
TMPGEnc Authoring Works 4 Problems
By DJ_OB1 in forum Newbie / General discussionsReplies: 0Last Post: 1st Aug 2009, 13:20
