Results 1 to 13 of 13
    Mar 2005
    Illinois
    Does anyone know if the Apple community has a program like "ISO BUSTER" for the Windows PC's?
    ISO Buster does many things. What, specifically, do you need?
    Mar 2005
    Illinois
    I do not think that ISO BUSTER works in OS X. I really do not want to use Virtual PC.
    I have a .iso file that I need to uncompress to the original format.
  4. Doesn't Toast handle iso files?
  5. Member terryj's Avatar
    N35°25.24068, W097°34.204
    Disk Utility should be able to mount it.
    http://www.macosx.com/forums/archive/index.php/t-28079.html
    "Everyone has to learn, so that they can one day teach."
    When I'm not here, Where can I be found?
    Urban Mac User
  6. toast handles iso images. click copy tab, image copy, drag/drop the iso image and click record.
    Mar 2005
    Illinois
    I don't have a problem burning the .iso files. I want to extract the files that are contained in the .iso files.....
  8. Member terryj's Avatar
    then use Disk Utility to mount the image and extract what you need from the mounted .iso.
    Toast will also let you mount the .iso, once you have drag
    and dropped it into the Copy window. Just select
    "Mount Disc" from the Utilities menu...
    Urban Mac User
  9. Member NarenFish's Avatar
    Feb 2003
    the snowy wastes.....
    OK, I'm confused. Doesn't an .iso mount automagically when double clicked. Am I missing something here?
    -laugh while you can monkey boy! - Dr. Lizardo
  10. Member terryj's Avatar
    No you are correct. Disc Utility is what Automagically
    unpacks and mounts it on a mac....
    You can also do it via Toast as well....
    Urban Mac User
  11. Member IsoBuster's Avatar
    Jan 2010
    Belgium & Australia
    PS. following information might help as well (eventhough mainly for search engine purposes and people landing here, since this thread is long dead).
    I created this text on subject:
    http://www.isobuster.com/linux-mac.php
  12. Banned
    Freedonia
    IsoBuster - I guess you're entitled to your opinion, but in mine you really should have just left this thread alone. Posting a link to a web page that basically says "Run a VM or an emulation program to get IsoBuster to run under Linux and Mac" is of dubious help. We'd really prefer you leave old threads alone unless what you have to add is really critical and I do not think "just run a VM or Wine" meets that definition.
  13. Member IsoBuster's Avatar
    Jan 2010
    Belgium & Australia
    I don't know, I think it is good information, relevant to the OP. Basically a way to run IsoBuster on Mac. A native Mac app would be prefered, but if it doesn't exist or if IsoBuster can deal with a situation that a comparable Mac application can not, then this is the only solution. It's good information, nothing more, to do with as the reader likes, ignore or check out.
    I only landed on this thread after investigating myself, so I figured I share my findings, but I'm more than willing to leave this thread alone now. I see no harm done, so I'm a tad surprised by your response.
